Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: AC Compressor Oil Check
    Quote Originally Posted by lewpopp View Post
    Jim,
    Take a taste of it and if it tastes like shit, it's from the macerator. Where do you think they got the name "Honey Dipper" from?
    I sure miss Lew!
    Dec 2010
    Penetang
    117
    Jim,
    I would not recommend isolating the compressor from the system to add oil unless you draw down the compressor under vacuum to remove the air and moisture that you introduce by opening the system. In order to repair the compressor, change or top up the oil you must place the compressor under vacuum to remove air and moisture introduced during repair.
    Quote Originally Posted by LNDYCHT View Post
    Jim,
    Your right on that Lee, I was not trying to "tell how" just wanted anyone to know it could be done and to not open the system to add oil. One should see a pro with all the special tools and knowledge on this.
  1. Leak check
    By gmcbuffalo in forum MISCELLANEOUS ITEMS
    Last Post: 08-27-2009, 07:26 PM
  2. Check Your Pricing Before You Buy
    By JIM CHALOUPKA in forum WHERE TO FIND STUFF: Links and Resources
    Last Post: 07-01-2009, 12:44 PM
  3. ABC Spell check
    By JIM KELLER in forum POG Forum for the Computer Challenged
    Last Post: 12-09-2008, 09:58 PM
  4. Check out these wheels!
    By ajhaig in forum Ah, Nice Coach...
    Last Post: 11-22-2007, 12:53 PM
