Results 1 to 2 of 2
Thread: Fresh water sentry problem
    Default Fresh water sentry problem
    My fresh water tank sentry alarm is screaming at me. The tank level is fine (full). My limited diagnosis is telling me that I have a problem with the Headhunter Tank Sentry. Is there another area that I should be focusing on? Is there a way to test to see if that is indeed my problem?
    Tony and Jenny Conder
    Abilene, Texas
    2008 Marathon D/S XLII
    2017 RAM 1500 4x4
    I turn my switches off to shut off the alarm.
    Not enough info to help, but if you have the level sensor book that will help with trouble shooting. I had to clean the sensor tube and recalibrate the one in my holding tank, did it per the book and it was easy to do.
    I did not empty and fill my whole tank, but used a deep small container that only took a few gallons of water to calibrate. It works on the pressure of a column of water, not volume.
  1. Fresh Water Auto Fill ??
    By 0533 in forum MISCELLANEOUS ITEMS
    Last Post: 07-04-2010, 07:28 AM
  2. Liberty Fresh Water Gauge
    By tdelorme in forum Ah Houston, I think we have a problem...
    Last Post: 01-21-2010, 10:16 AM
  3. Heating the fresh water tank
    By merle&louise in forum Ah Houston, I think we have a problem...
    Last Post: 10-22-2008, 09:23 AM
  4. Extra fresh water tank?
    By adamdegraff in forum NEW MEMBER INTRODUCTION
    Last Post: 05-09-2008, 01:09 PM
  5. Fresh Water Heaters
    By dalej in forum WHERE TO FIND STUFF: Links and Resources
    Last Post: 02-11-2008, 10:01 PM
