Hey All,
as we head from frigid Chicago up to even colder South Dakota for a couple of shows, my front heat exchanger stopped working. This is the unit attached to the webasto heated liquid. (Sorry, I know, my terminology stinks!) Last night I noticed that the fan was struggling. Then, I noticed it started to smell like a motor that was burning out (or, trying to spin, but meeting with sufficient resistance that it was overheating.) Well, this morning, it won't spin the little turbines at all. Well, actually, it will if I put on the 24 volt option instead of the 12 volt. But even with 24 volts, it struggles to get moving and never spins fast more than a few rotations. When I try to spin it by hand, it will move, but has a constant drag on it. (not sure if that is normal or not.)
So, this looks difficult to pull out. It is attached to the coolant lines and jammed into the front/passenger dash area. I see that I could probably pinch off both hoses, make a huge mess, take the hose clamps off the lines, and take out the whole unit. What do I need to fix though? It is getting plenty of heat. The fan just don't spin. Bearing? Motor? Whole unit?
I am on the north side of suburban chicago. (drove by Liberty by accident the other day! exciting :-) I'm headed up to MN, then over the SD later this week. But for now, I'm enjoying my relatives and old friends... and now, fixing, the bus:-)
Any thoughts what I should do?
Thanks,
Adam
