Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Replacing bulb in Drivers Headlight
    Feb 2008
    Lunenburg, NS
    515
    Default Replacing bulb in Drivers Headlight
    I have the replacement bulb, see below. But the light seems sealed. How do I install the bulb in the headlight?
    Mar 2006
    ON THE ROAD IN THE SOUTH
    2,825
    Lightbulb
    Remove the lens/bulb holder, by removing the nuts in the corners.
    Remove the socket from the lens.
    Remove the bulb from the socket and assemble in reverse order.
    IF YOU ARE USING A HALOGEN BULB DO NOT TOUCH IT WITH YOUR BARE HANDS. THE OIL ON YOUR SKIN WILL MAKE IT BURN OUT PREMATURELY.
    IF YOU HAVE ALREADY TOUCHED IT WIPE IT OFF WITH ISOPROPYL ALCOHOL, AND HOLD IT WITH A CLEAN CLOTH.
    If I'm wrong try something else, just going from your pictures, but don't touch the bulb with bare hands, whatever you do!
    Feb 2008
    Lunenburg, NS
    515
    I can only see the two plastic nuts shown in the first photo in the corners. Are these the two you are talking about?
    I have avoided touching the bulb shown in the last photo that BrainE was gracious enough to give me. If these are the two nuts you are talking about I assume lens folds down to access the bulb holder.
    Mar 2006
    2,825
    Can't tell you for sure Lloyd. take the two off and maybe the next step will be obvious, like tilt it forward and slide up?????
    Here's a link to several that have done it. PM them for specifics.
    http://forum.prevostownersgroup.com/...ighlight=bulbs
    http://forum.prevostownersgroup.com/...ht+replacement
    Mar 2006
    2,825
    Look at this one and the post by Jerry, #11.
    If you take the nuts off maybe you have the hinge?
    Mar 2006
    Santa Barbara
    3,177
    Hi Lloyd. I would think its the two hex head screws on the right, and hopefully it is hindged on the left side. Mine hindges open with the removal of one allen screw on the front of the light frame.
    Apr 2006
    Battle Ground, WA
    851
    Lloyd,
    Remove the 3 hex bolts (19) with the large washers (18) that mount the light assembly to the structure with a 7/16 socket and extension. Remove the assembly and you can access the back of the light, unplug the wires and change the bulb. Don't turn the adjusters (5) or you will disturb the aim.
    Before you reassemble the unit, test the headlight. If it doesn't work the local NAPA store will have a new #9004 replacement. You might consider replacing both bulbs with Sylvania Silverstars, they are much brighter than the original bulbs. (The one you have might even be a Silverstar). Good luck.
    Jasper
    3,775
    Now that's what I call help!!!! Instructions with pictures, you are da man Mole Boy..
    Petervs Guest
    What was not mentioned was the fact that the Moleman actually alerted Lloyd that he had a bulb out and immediately handed him a new bulb!
    Joe Cannarozzi Guest
    Looks like he needed to install it for him too
  1. Headlight change?
    By adamdegraff in forum Busted Knuckles and Greasy Jeans
    Last Post: 11-25-2008, 02:06 PM
  2. Turn signal bulb?
    By Tully in forum PARTS AND PIECES FOR SALE OR TRADE
    Last Post: 05-27-2008, 09:22 PM
  3. Dash Bulb Change to 12V
    Last Post: 12-21-2006, 11:09 AM
  4. Daytime Headlight Switch
    By Jerry Winchester in forum Busted Knuckles and Greasy Jeans
    Last Post: 05-19-2006, 08:57 AM
  5. Headlight trim
    By ken&ellen in forum WANT/NEED PARTS?
    Last Post: 02-27-2006, 11:43 AM
