Can anyone lead any insight into what is the official color of the Prevost Gray used in the engine compartment? I think I must be color blind!
Any paint numbers is appreciated.
Hector
Hector
I used a gray paint from Tractor Supply and it is fairly close in color. After a few months and a few cleanings it looks the same.
If the brand is important I can get it and post it. I am sure you can find a Tractor Supply nearby.
it is a 2 part paint that comes out of Canada. I will try and get you the info next week, we are leaving in about 1 hour for Havasu.
Hector,
The data you need for an exact color match is known as a Pantone number. Prevost may be willing to provide you with that. A commercial automotive paint shop should be able to mix up a batch using the number.
Hector,
Prevost parts gave me an Imron code #10094 light gray as the OEM finish, I found an American Finishes code # 46025 Ghost Gray it is a very close match in a single stage paint that is easy to use.
