I need to replace a hot water circulating pump on my Wabasto unit. It is a 12 volt unit, so that eliminates any Prevost replacements (the Prevost parts catalog only list 24 volt units). Country Coach is not answering their phone. They state they are restructuring (a realignment of resources is much needed in the support area for sure).
I would prefer an exact replacement for ease of replacement. Any ideas of where Country Coach gets these 12 volt hot water circulating pump?
A Side Bar:
I removed the faulty water pump to clean the brush contact area on the armature to get a little more service while searching for a new replacement. When removing one of the pumps in the crowded area where the Wabasto is mounted, dealing with the antifreeze that will leak out is a problem (The Wabasto is located lower that the engine and the exchangers located in the coach). I used two short pieces of 1/4" X 2" flat bar clamped together with a 4" inch 'C' clamp to clamp each the green hoses shut to prevent water leakage. It worked great! FYI
I had read on the forum that converters have a special pair of vise grips that are designed to clamp hoses, but do not have one in my tool bins.
Hector
