The ceiling and wallpaper in my enclosed water closet were looking real bad. So today I started a project to redo the water closet. So I need some help deciding what to do.
1. The old ceiling was a velour looking material with a very thin foam backing that was glued to the plywood ceiling.
2. The walls are covered in wallpaper that I would like to remove and replace with the same wallpaper. There is a roll of wallpaper that came with the coach.
3. The mirror behind the sink has 2 small cracks in it so it needs to come off and be replaced with something.
A. I need recommendations on a new ceiling material and how to install it. I was thinking something smooth and light colored that could be glued up like the old material. Any ideas? I this works out well, I will eventually redo the entire ceiling in the bus.
B. What is the best way to get the old wallpaper off?
C. How do I get the mirror off?
Any and all hints, tricks and sources of supply are welcome.
Thanks
