Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Entertainer Shells?
    May 2008
    345
    Default Entertainer Shells?
    Hey, I was wondering, what is the difference between a regular Prevost and an "Entertainer" shell?
    When I was looking for a bus, I was warned by a number of different folks that the "entertainer" models were not of the same quality that the motor homes were. I guess I just took it as fact after hearing it so many times. But now I have a friend who needs a bus for an upcoming tour and I'm having trouble explaining to him the difference.
    Anybody know?
    Thanks,
    Adam
    Nov 2007
    926
    Hello Adam,
    Here is a link to Prevost Car: http://www.prevostcar.com/cgi-bin/pa...xl2entertainer
    I think that the height was 89" inside and maybe extra storage below and of course the end configurations have many bunk beds, three on a side in some cases, lounge etc.
    I do not feel that Prevost anyway made the shell with any less quality.
    The chassis difference is in the wheelbase.
    If you look up photos of coaches that were converted for entertainers you will notice that the rear overhang is identical to that of a 40 foot coach. Unlike our 45 foot coaches, 33" of the difference between a 40 footer and a 45 is in the distance between the axles, and the remaining 27" is rear overhang.
    I have heard theories about that with the most common being that the additional wheelbase serves two purposes. It provides more bay area for storage or equipment, and the longer wheel base minimizes pitching motions so the ride is more comfortable for folks trying to sleep in the bunks.
    The conversion is also different. Bunks instead of a lot of closet space are the most noticed feature, but there are other differences. The rear is often a lounge area. The kitchen and dining area is also minimized. The interior is often more durable and institutional because it is not a home, but a transportation appliance. It is going to get 80,000 miles of living and use per year. The systems are different also. It is common to see five roof airs. It is common to have two generators. The systems are robust because on-road failures cannot be repaired if the travel schedule is tight. Repairs have to be made when they can be fit into a gap in the schedule so redundancy is important.
    Some entertainer interiors are similar to our conversions, but while there may be some similarities such as a rear bedroom and a larger kitchen and dining area, the focus is less on the decor, and more on durability and resistance to wear and tear.
    My guess is that a loaded entertainer's coach is well over the front axle limits because of the extended wheelbase and the fact that less weight is cantilevered beyond the rear axles.
    donniev Guest
    Default Entertainer
    The Substructure Of The Shell Is Not Stainless As The Conversion Shell Is. Thats A Big Savings To The Entertainment Industry.
    Donnie V
    The entertainer shell is stainless steel according to the Prevost Specs.
    Nov 2007
    926
    It would make sense that they would cut this corner to save some $$ but Jon is right at least for the current shells:
    taken from Prevost car website:
    XLII Entertainer
    The 45-foot Prevost XLII ENTERTAINER coach shell is configured to suit the needs of traveling entertainers and their crews. The sublime riding comfort is the most sought-after characteristic of the Prevost XLII ENTERTAINER, providing entertainers and their crews with unparalleled riding stability for sleeping and lounging while on the move.
    The Prevost XLII ENTERTAINER features Prevost's independent suspension system with integral structure and stainless steel outer shell (up to window level). Floor-to-ceiling height is a full 89 inches, the tallest in the industry. Under-floor cargo bays post a whopping 433 cubic feet to accommodate personal belongings and fragile items. The ENTERTAINER bus shell also features Prevost's special engine/transmission mounting, which virtually eliminates vibration and engine noise for a serenely quiet travel environment.
    This is a moot point, but if strength were needed, such as to support the greater span between axles, stainless might not possess the needed strength.
    In that case from an engineering point of view certain high strength steels would be a better choice. But obviously Prevost does not need that additional strength and have chosen stainless steel.
    The front axle limits are the same as for the motorhome conversion so if I saw a potential drawback besides the longer turning radius it would be the ease with which the front axle limits could be excessively exceeded.
    Mar 2006
    Santa Barbara
    3,177
    Some other things to consider, the Converters offer many options which you will not find on entertainer buses. The lighting system , outside patio awnings, Galley slides, outside tv's, refer,bbq, and stereo, Interior finishes, passenger seat,
    washer/dryer, clothing closets and drawers.
    Some Coaches may have some of these but those are more customized.
    donniev Guest
    Default Entertainer
    I Said The Substructure Is Not Stainless Steel Like The Conversion Shell, Not The Exterior Stainless. Unless They Have Changed This.
    Donnie V
    Mar 2006
    ON THE ROAD IN THE SOUTH
    2,825
    I saw that Donnie, and also Bruce's quote of Prevost,
    "The Prevost XLII ENTERTAINER features Prevost's independent suspension system with integral structure and stainless steel outer shell (up to window level)."
    I think many misread that to mean the structural framing is stainless. I really doubt that that is the case!
  1. Prevost Entertainer Bus Accident
    By GDeen in forum MISCELLANEOUS ITEMS
    Last Post: 11-21-2009, 02:50 PM
  2. Entertainer vs. Motorhome
    By Jon Wehrenberg in forum MISCELLANEOUS ITEMS
    Last Post: 03-06-2009, 05:25 PM
  3. 85 Entertainer Buses for sale
    By Danss in forum Target Practice
    Last Post: 06-25-2008, 08:15 AM
  4. Conversion Shells up 10% in 07
    By jack14r in forum Prevost Shells and Prevost Car Company
    Last Post: 05-05-2008, 01:27 PM
  5. New EGR Stacks on Shells
    By Just Plain Jeff in forum Quirks and little known Prevost Information
    Last Post: 01-13-2007, 03:51 PM
