Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 41
Thread: Dash Crash
  1. #31
    Jan 2007
    1,600
    Jamie, What is a Dimverter ? What does it look like and where does it go ? Computer dash owners need to know.
    99 Country Coach 45XL
    Jeep Liberty
  2. #32
    Nov 2006
    Huntsville
    3,135
    Jamie, I second Jim's question. I thought it might be the dimmer switch that I mentioned in an earlier post, but I'm not sure either?
    Dale & Paulette
  3. #33
    Apr 2006
    Lake Forest
    2,486
    And what happened to the lone wire?
  4. #34
    Oct 2008
    Tavares
    1,088
    Default Follow Up
    The loose wire simply went into the block on the botttom right. I do not really know what it did or did not do. It seems the dimverter shorted out somehow or " just got old"?? The " Dimverter" controls the backlight for the screen-- I was told the screen was still working I just could not see it. Anyway-- here is a picture of it. Ps I was refered to Nick Hessler who was a HUGE help with this.
    Jamie
    2005 Marathon H3-45 # 0867
    2013 Chevy Avalanche
  5. #35
    May 2006
    LaBelle
    474
    Jamie,
    Where did you get the new Dimveter board from?
  6. #36
    Oct 2008
    Tavares
    1,088
    I got it from Computer Dynamics I have all the info if needed.
  7. #37
    Nov 2018
    Dixon
    32
    Not sure how many Country Coach glass dashes are still in use. Hopefully this info can help someone with this type of failure.
    We left home the end of December. Towards the end of the first day the dash went black. Continued on using a stand-alone Silverleaf VMS-200EL for engine gauges that was installed by a previous owner and a Garmin GPS for a speedometer. After removing the glass dash panel I found a blown 5 amp fuse in the +12v power to the screen power supply. I traced the short to the dimverter board. When I called Computer Dynamics (the original board supplier) the next day they said that board was no longer available. The main component on the dimverter board is produced by Endicott Research Group. Endicott had a replacement component (R202243 - 10 lamp DC to AC inverter) as the original part had been superseded. I ordered it and had it shipped to a FedEx facility on our route. I desoldered the old one and soldered in the new one at the kitchen table in the coach. The dash is working once again. It's been working like it should for 15 hours of driving so far. If it quits I'll update this thread.
    Joe and Michelle
    98 Country Coach XLV
  8. #38
    Mar 2013
    Chicago
    3,988
    What would happen to the average RVer who isint savy and not a forum participant with a failure like this. Imho Joe does not fit this description but I think most do.
    Thank God for silverleaf and gps.
    1990 Peterbuilt 377
    3406 B Caterpillar
    13 Speed Roadranger
    No Norgrens
    1 day on paper no machines
  9. #39
    May 2012
    Beverly Hills
    4,652
    That dimverter board is likely the #1 failure item with the CC glass dash.
    What great effort to find a replacement item. How lucky the replacement item has the same form factor and pin placement.
    Thanks for sharing. Did you contact Miles to see if he still has dimverter modules?
    Gil and Durlene
    2003 H-3 Hoffman Conversion
  10. #40
    Nov 2018
    Dixon
    32
    I know this forum is essential to me if I'm going to be able to keep our bus in good repair. That and a lot of good luck!
    I tried to contact Miles via e-mail around a year ago to ask him a question and never heard back. Does he still participate here on POG?
    Joe and Michelle
  1. Dash AC problem
    By Alek&Lucia in forum Ah Houston, I think we have a problem...
    Last Post: 08-16-2009, 04:25 PM
  2. Dash AC on 03 Royale
    By Bill1170 in forum Busted Knuckles and Greasy Jeans
    Last Post: 03-23-2009, 11:34 AM
  3. Dash A/C Compressor
    By truk4u in forum WANT/NEED PARTS?
    Last Post: 01-08-2009, 03:47 PM
  4. Need New Dash Panel
    By Will Garner in forum WHERE TO FIND STUFF: Links and Resources
    Last Post: 12-06-2008, 09:45 PM
  5. Liberty Dash 98
    By lewpopp in forum Ah, Nice Coach...
    Last Post: 11-29-2006, 10:06 PM
