Results 1 to 2 of 2
Thread: Inverter Settings ...
    Apr 2006
    Lake Forest
    2,486
    Default Inverter Settings ...
    Does anyone know the correct settings for a Trace inverter for the battery charging of AGM house batteries.
    IN particular I was wondering about those paramters listed on page to (setup -> battery charging), which include
    1. Bulk volts DC
    2. Absorption time (h:m)
    3. Float volts DC
    4. Equalize volts DC
    5. Equalize time (h:m)
    6. Max charge amps DC
    IN particular I was worried about the next, because mine is set for "lead acid". I have AGM batteries, however AGM does not appear to be a selectable entry?
    7. Temp Comp (Lead Acid, NiCad) (AGM doesn't seem to be a selection)
    Any other paramters to check on this? Bus is 250 miles away, but I'll probably be going out this weekend to check.
    Ray,
    Try this site. I refer to it frequently, and they also will respond to questions. What I also do is go to the battery manufacturer's web site.
    http://www.windsun.com/Batteries/Bat...ting%20battery
    I would also suggest you go to the inverter manufacturer's owner's manual. My Heart Interface manual is excellent and I am sure all inverter manufacturer's provide advice on inverter settings.
  1. Retarder Settings/Allison Transmission
    By 0533 in forum Engines, transmissions, axles and wheels
    Last Post: 04-01-2009, 05:55 AM
  2. Inverter Repair
    By dreamchasers in forum Sparky's Corner
    Last Post: 11-04-2008, 07:44 AM
  3. Inverter fan replacement
    By jelmore in forum Sparky's Corner
    Last Post: 10-22-2008, 09:22 AM
  4. Inverter settings
    By bwalz in forum Sparky's Corner
    Last Post: 05-20-2008, 01:10 PM
