Results 1 to 10 of 10
Thread: Window repair
    JamesH Guest
    Default Window repair
    If you have a 2000-2001 Prevost and have had your awning leafs cloud up. I have a source that can repair them at a cost of approximatley $300.00 each
    Alexandria
    2,161
    James,
    Can you explain "awning leaf"?
    Thanks,
    Mike
    JamesH Guest
    The awning leaf is the lower part of window that opens out at the bottom
    JamesH Guest
    Quote Originally Posted by MangoMike View Post
    James,
    Thanks,
    Mike
    The lower part of window that opens out for ventilation
    Apr 2006
    Lake Forest
    2,486
    James, just to confirm, is this for the XL model? The changeover to XL2 models came in the 2001 model year, so I'm a little unclear as to which models your friend can fix.
    If XL models, then I would expect that older coaches would be appropriate too?
    Apr 2006
    Battle Ground, WA
    851
    Only slightly off-thread... Has anyone experienced an air seal leak in an awning window? Have adjusted the latch and tried to twist the window slightly, no luck. Can the seal be replaced?
    Oct 2008
    Eufaula
    1
    jamesh
    can you give more info, on the leaf, is this a repair or replace?
    is it for an XLII?. I have one leaf cloudy, and one if look just right you can see the cloudy in between the glass.
    Is this a do it your self fix? If not will the repair guy be at Oct. ralley?
    Aug 2008
    Walla Walla, WA.
    504
    Brian, are you revering to the seal around the push rod?
    Apr 2006
    Battle Ground, WA
    851
    Larry, I was referring to the seal around the edge of the awning window. I have one that leaks at the lower, forward corner. Noisy going down the road.
    Nov 2007
    926
    I took a quick look at James Profile and saw a picture of what appears to be an XLII. If so, his awning opining window clouding is on his XLII.
  1. Out the Front Window
    By Loc in forum MISCELLANEOUS ITEMS
    Last Post: 05-12-2020, 07:48 PM
  2. Snap on Window Sun Screens
    By lloyd&pamela in forum WHERE TO FIND STUFF: Links and Resources
    Last Post: 10-04-2009, 05:38 PM
  3. window extension
    By bluevost in forum PARTS AND PIECES FOR SALE OR TRADE
    Last Post: 04-02-2009, 09:48 PM
  4. Front window shade...
    By Tully in forum Ah, Nice Coach...
    Last Post: 02-04-2009, 01:53 AM
  5. Window Coverings
    By jimshoen in forum WHERE TO FIND STUFF: Links and Resources
    Last Post: 02-24-2008, 09:19 PM
