Results 1 to 9 of 9
Thread: What is This Part
    Nov 2006
    Huntsville
    3,135
    Default What is This Part
    I noticed this device on my air compressor is leaking from the hole as shown in the picture. I assume this is some kind of pop-off valve, but I don't know for sure. Is it something I can clean up and lubricate and get to working again, or do I need to replace it?
    Dale & Paulette
    sawdust_128 Guest
    Quote Originally Posted by Roadrunner View Post
    It appears to be either a safety over-pressure release valve or a moisture blow out valve. Call Thomas 800-848-7735 to see if they have a rebuild kit.
    Personally, I'd replace it.
    May 2008
    Boerne, Texas
    401
    It is a relief valve and not a moisture relief valve, otherwise it would be on the bottom or have a tube to the bottom (which I have never seen personally) of the vessel. I agree - replace it, I doubt there is a rebuild kit for it anyway. Good luck. Should be easy, now that you gotten to it.
    Nov 2006
    Huntsville
    3,135
    I am sure it isn't the moisture valve. As you said, it is on the bottom. I hit a siwtch to activate the moisture drain valve.
    Dale & Paulette
    Nov 2006
    Huntsville
    3,135
    Thomas finally called me back, and it is a check valve. They are sending one to me. Thanks for the input.
    Dale & Paulette
    sawdust_128 Guest
    What exactly does it check? Does it keep the system pressurized when you release and drain the tank? Interesting.
    Joe Cannarozzi Guest
    And an adjustable one at that.
    Nov 2006
    Huntsville
    3,135
    They didn't tell me what it checks; maybe it prevents the air from flowing backwards in the supply line.
    Dale & Paulette
    May 2008
    Boerne, Texas
    401
    I hit a switch to activate the moisture drain valve.
    Uh oh, you are going to get picked on for that statement.
  1. OKC some images Part 1
    By sawdust_128 in forum RALLIES AND GET-TOGETHERS
    Last Post: 11-08-2009, 02:14 PM
  2. Is this an awning part?
    By jelmore in forum WANT/NEED PARTS?
    Last Post: 03-11-2009, 12:09 AM
  3. What Part Is This??
    By tdelorme in forum WHERE TO FIND STUFF: Links and Resources
    Last Post: 12-28-2008, 06:39 PM
  4. The part you didn't hear!
    By dalej in forum On the Lighter Side...
    Last Post: 12-05-2007, 01:18 PM
  5. Webasto Part Needed
    By MangoMike in forum WANT/NEED PARTS?
    Last Post: 10-26-2006, 10:42 PM
