Results 1 to 6 of 6
Thread: Liberty Macerator Pump
    Jasper
    3,775
    Default Liberty Macerator Pump
    Couple of questions for the Liberty Owners with Macerator Pumps. Mine has a pump mounted on top the black/grey tank that is plumbed to the bottom of the tank by 1 1/2" PVC and then has a garden house hookup under the starboard engine access door. I put a quarter tank of water in and the pump runs, but won't pick it up.
    1. Is the pump self priming
    2. The dash switch is a momentary rocker switch. I find it hard believe you have to hold the switch down to pump the poo out.
    I know this is Jdub's forte, but he's not good with Liberty questions.
    Mar 2006
    Santa Barbara
    3,177
    Hi Tom. My Macerator blew the fuse last time I tried it. My tank was full at the time. Let me know what you find out.
    Feb 2006
    Bristol, Tn
    1,647
    Default Advice that Sucks
    I never tried it, but I heard you had to treat it like you are siphoning gas from your Dads car when you were a kid.
    Roger that!
    2008 Liberty DS XL2
    2023 Denali Ultimate
    My 6th Prevost
    Jul 2007
    East Texas
    946
    Quote Originally Posted by rfoster View Post
    And JDUB told you that, right? I hope your eating those smart'n pills that you find out in the woods.
    Nov 2006
    thomasville,nc
    1,209
    I have been told that the impeller in the pump is rubber and it is self priming but if it is run without water it will fail very quickly.I had a blockage in mine once and I hooked a garden hose with an adaptor to it and turned on the water for a few minutes and it worked,this would also prime it.Mine will run for about 10 minutes at a time and then shut off,it will pump the tank down about 40% in that time,I was told that the timer is to prevent the impeller from running dry.
    I must be lucky. I don't have a use for my macerator pump. So as a result, apart from turning it on after I got the coach I never used it until just before Spearfish, and then out of curiosity.
    It ran for about 10 seconds and then the noise changed and out came the poop.
    If it isn't pumping then it seems priming is in order. If I recall JPJ recommended sucking on the end of the hose. To me all that seems silly when we have all that is necessary without the pump. Eliminate the pump and using the opening in the top of the tank, add an air fitting. Start the aux pump and pressurize the holding tank. If it works as planned the poop will exit the tank at a fairly brisk pace. Use caution however because if the tank explodes it could ruin your whole day.
    No charge for this excellent advice.
  1. Macerator Use And Maintenance
    By JIM CHALOUPKA in forum The 'Biz" of Prevost Ownership
    Last Post: 10-21-2009, 08:11 PM
  2. Macerator Pump
    By Richard Barnes in forum Ah Houston, I think we have a problem...
    Last Post: 07-06-2009, 03:30 PM
  3. macerator pumps, Liberty Coach
    By ken&ellen in forum Quirks and little known Prevost Information
    Last Post: 04-05-2009, 07:50 AM
  4. 1995 Liberty EL: Liberty Coach stock #5102
    By Jim_Scoggins in forum Ah, Nice Coach...
    Last Post: 08-12-2007, 05:59 PM
