OK, so one of the critical components directly related to the safe operation of the bus is failing.
The Black and Decker coffee maker (ODC 325) that is original equipment on our Liberty now fails to transfer water from the tank to the filter basket. Since there is a cabinet dedicated to housing the coffee maker, and so far I haven't found a replacement that will fit, I would like to attempt to repair the existing one.
The first challenge is to remove the tamper-proof screw in the back that holds things together. Any ideas how to get this torx screw out while dealing with the little "post" centered in the middle of the screw to keep me from getting my torx bit in there?
And, if I can get this apart without destroying the entire coffee maker, any ideas as to why this won't transfer water from the tank to the basket?
