Results 1 to 4 of 4
Thread: Tag Axle Air Pressure Switch
    dreamchasers Guest
    Default Tag Axle Air Pressure Switch
    Several months ago, I remember (not well enough) reading a post of a member that would hear air escaping, as if in a discharge, coming from the rear of the coach after the coach was parked for a few days.
    As I recall, it was determined that a pressure switch exist that monitors the Aux air, and once the pressure would leak down, this pressure switch would release the air from the tag axle air bags.
    My question is, what is the purpose of this switch and at what pressure does it release?
    Any help is appreciated.
    Hector
    dreamchasers Guest
    Default I Found the Answer
    I found the answer.
    Thanks,
    Hector
    Aug 2008
    Walla Walla, WA.
    504
    Hector, care to share what you discovered?
    Larry
    dreamchasers Guest
    I believe the reasons for my symptoms of the tag releasing air is a leak in the aux air system. As stated in the below link, once the aux air gets below a certain value, the tag axle air bag is released due to low aux air pressure. Not by a switch, but because the aux air pressure has reduced to a point that the tag axle norgren 'deselects'.
    The link below is the one I was looking for.
    http://forum.prevostownersgroup.com/...ead.php?t=1713
    Hector
  1. speed switch
    By dreamchasers in forum Electronic Gizmos, Computers and Communications
    Last Post: 01-22-2009, 07:49 PM
  2. The Dog Switch
    By jelmore in forum Sparky's Corner
    Last Post: 10-09-2008, 07:04 PM
  3. were is the switch
    By Jim_Scoggins in forum MISCELLANEOUS ITEMS
    Last Post: 02-07-2008, 07:06 PM
  4. So What' this Switch?
    By MangoMike in forum MISCELLANEOUS ITEMS
    Last Post: 12-03-2007, 11:03 PM
  5. 30 amp transfer switch
    By bill&jody in forum PARTS AND PIECES FOR SALE OR TRADE
    Last Post: 05-28-2007, 09:18 PM
