Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 54
Thread: H340 Wanted - "Update"
    The watch dog is the monitor that provides a number of functions. It will start your generator if on "auto-start" to keep the batteries charged, it will start if you command it to start with shore power disconnect, and it will shut down the generator if it overheats or loses oil pressure.
    It can be disconnected, but you lose the automatic shutdown in case of mechanical problem on your generator.
    Jody,
    The webasto is a diesel fired burner which heats your water, and provides for heating as well.
    As a difference to the cruise airs, which might also provide heat, the webasto system can work on 12V, while the cruise airs require that you either be plugged into shore power, or running the generator.
    The webasto's generally work very well, and are easy to repair/maintain. There are several threads here in the forum regarding various repairs.
    I don't believe cruise air heat functions below about 40 degrees F. IN that case only your webasto is going to keep you warm.
    Jul 2007
    East Texas
    946
    Good going on the generator, Jody. For a quick repair on the plug, just wrap the stripped threads with five or six layers of teflon tape and see if that won't hold the connection.
    The Webasco is your diesel fired heater system. Your coach will have two separate thermostats for that system. Not the same ones as the CruiseAirs. If the Webasco is working properly, you will love it. Keeps the entre coach nice and warm with moist heat. The CruiseAirs will also provide heat, so you just decide which system you prefer. If the Webasco is not working properly, there is a ton of info on POG to help you get it up and running. We love our Webasco.
    The air pressure for the door can be bumped up. Look in the first compartment drivers side. You will see a number of 1/4" air lines and the pressure is controlled by a valve close by in that compartment. Lift it up, screw it in a turn and push it back down. Liberty labels all the air lines and each line has it's own small needle valve. Be sure the valve for the pocket door is opened all the way. That may be all you need to do to fix the door problem. I wouldn't modify the system. Once you get it working properly you will like it.
    jkbriggs Guest
    Just for my clarification, is Webasco for when parked, can/should it be used when on the road? I do have OTR which I assume produces heat also?
    You can use it going down the road for cabin heat when it is nessessary during extreem conditions.
  6. #26
    Just a note here. You see many people spelling this product name with a C, when it's a T. The product is a Webasto heater. To the very best of my knowledge, there is no Webasco. Luckily however, if you are looking for parts, and Google Webasco, it comes back with Webasto!
  7. #27
    Thumbs up
    Ray, you could get sheep over remarks like that.
  8. #28
    Yeah, maybe. Although I hope that my intent was obvious. Not to burn anyone, just to educate.
    ray
  9. #29
    1,140
    Hey Ray,
    If any of the California Cartel needs WEBASTO parts (Vehicle Systems, Inc), you will be passing them on I-76 as you come to our house, or we can run up there after you get here. Its only 32 miles. I need to run up there for a new nozzle for our coach..
  10. #30
    Thanks Jim,
    We actually have a pretty decent supplier I found down in the Fontana area when I had to replace the fuel pump in my unit. I believe Ken also used them. But, before I come through Denver, I'll check and see if anyone needs anything.
  1. Entrance Door Won't Open - "Barney" Inside
    By mcirco in forum Ah Houston, I think we have a problem...
    Last Post: 11-04-2012, 10:51 AM
  2. 20" Sony TV Wanted
    By jimshoen in forum PARTS AND PIECES FOR SALE OR TRADE
    Last Post: 05-04-2009, 09:26 PM
  3. Emergency Question about "Check Engine" light
    By Jeff Bayley in forum Sparky's Corner
    Last Post: 01-09-2009, 08:17 PM
  4. Rvac A/c System With Two Position "in-duct" Damper
    By 0533 in forum Ah, Nice Coach...
    Last Post: 02-10-2008, 04:29 PM
  5. Tie a "Turbo Encapsilator" to a Volvo engine and Walla
    By mike kerley in forum MISCELLANEOUS ITEMS
    Last Post: 06-23-2006, 03:41 PM
