Results 1 to 10 of 21
Thread: Holding Tanks Level Monitors
    Dec 2020
    Goldsboro
    145
    Anyone care to detail installation of Sea level tank monitor and reliability
    George and Joan
    1998 Royale Aug 2019
    Goldsboro NC
    Just added a 2022 Ford King Ranch
    May 2009
    Regina, Sask, Canada
    129
    Hi George,
    I installed a Sealevel system this winter and it went well. One thing I did that might be a little different is being my tanks were 28 and 22" tall they call for two sensors each to be installed in series to read the complete tank levels. instead I installed one sensor strip on the bottom of my fresh tank and one strip at the top of my Grey Black tank. So I know when one tank is on its bottom 2/3 (fresh) and when my Grey Black is filling its top 2/3. Initally I was only going to install on one tank as when one empties the other fills fairly equally so didnt see a reason to measure both tanks. ( I normally fill my fresh tank and dump the grey at the same time. Dont normally run on park pressure.) The way I have it installed now does give me accurate measure on when one is dropping and the other is rising so thats why Ive installed it like I did. So far so good. A lot cheaper then repairing the Head Hunter system I had before. And quieter!
    Craig Lenz
    Yellow Grass, Saskatchewan
    1996 Angola XLV #5688
    Apr 2018
    Crossville
    278
    You can find the installation instructions for the different models here:
    SeaLevel
    I've had the system on three different coaches. Never a failure, never anything but rock solid indications.
    Oct 2019
    Montgomery
    64
    I also recently moved from the Headhunter fish tank air pump to a Sealevel system. If you have poly tanks, its a no-brainer. The system works flawlessly and is extremely accurate. Get the Bluetooth version and I bet you’ll be thrilled.
  1. Changing pressure in main tanks
    By nrhareiner in forum Ah Houston, I think we have a problem...
    Last Post: 03-22-2009, 10:43 AM
  2. Rear view monitors
    By Kenneth Brewer in forum MISCELLANEOUS ITEMS
    Last Post: 02-16-2009, 11:01 PM
  3. Liberty Holding Tank Level Gauge
    Last Post: 02-02-2009, 01:09 PM
  4. Water and Holding Tanks
    Last Post: 11-09-2006, 10:24 PM
  5. Prevost Level Low Level
    Last Post: 02-25-2006, 04:33 PM
