Results 1 to 7 of 7
Thread: RV Dump on Chicago North Side?
    May 2008
    345
    Default RV Dump on Chicago North Side?
    Anybody know of a place to dump on the north side of Chicago? I'll be in Evanston, Park Ridge, Paletine, etc.
    Thanks,
    Adam
    The Dave Matthews band can probably tell you where NOT to dump.
    If you need places to dump around the country the best bet is to find the closest campground. They will generally charge a small fee.
    Flying J truck stops have dump stations, but they are not the easiest to get at with a bus.
    Or you can go on line to this site: http://www.rvdumps.com/dumpstations/
    Alexandria
    2,161
    All the Love's Truck stops I've used have DMB* stations.
    *Dave Matthew's Band
    Joe Cannarozzi Guest
    There are none of those around here Mike. Adam there is no and I mean NO campgrounds even close. Do you have a macerator pump? If you have a grey water bypass get that in play.
    There is a porta-potty co. called "The Great Event" that could probably come and do the dirty deed or check the local yellow pages for a closer one.
    Now you know what lead Mr. Mathews to his mistake.
    Mar 2006
    Santa Barbara
    3,177
    You might check with Greyhound and other private transportation companies in the area to see if you can pay to use their dump station. Liberty is in Chicago as well and might accomodate a POG member.
    May 2007
    Port St. Lucie, FL
    1,745
    We stayed in Marengo, which is just to the north west of Chicago. Nice campground and they can accommodate you.
    However, you DO NOT want to drive to Liberty Coach in an attempt to dump.... very busy, tight and congested industrial area that would be a very difficult place to drive the bus around.
    Good luck
    May 2008
    345
    Default Thanks!
    Thanks everybody for the help. I think my best bet is to dump on my way into Chi, and then be conservative while there, and then dump on my way to out of town to Minneapolis.
    Much thanks,
    Adam
  1. What A Dump!!!!!!!
    By Jamie Bradford in forum OVERNIGHT PARKING
    Last Post: 05-04-2009, 02:01 PM
  2. Chicago
    By phorner in forum TIPS ON TRAVEL
    Last Post: 07-22-2008, 08:52 PM
  3. Chicago
    By ajhaig in forum OVERNIGHT PARKING
    Last Post: 09-09-2007, 06:33 PM
  4. RV Dump Station Directory
    By Ben in forum WHERE TO FIND STUFF: Links and Resources
    Last Post: 12-12-2006, 09:33 PM
