Does any body recognize these? Part of a tow bar assembly but are these particular to the previous owners TOAD? Brand?
P.S. I know the belt and the Lic. Plate bracket -- just in case.
Maybe a Blue Ox adapter to Roadmaster?
I believe that those are parts from a Roadmaster tow bar. The long piece is the part that attaches to the towbar. The other 2 smaller pieces are pieces that attach to the vehicle. Usually those 2 smaller pieces are particular to a specific make and model of vehicle.
Wendy and Rick DeSilva
'08 Marathon H-3
2017 F350 platinum
Mahwah, NJ
Brant Beach, NJ
Pelican Lake, Fla
I think you are correct. I looked at the roadmaster web and it looks very similar.
It is definitely a Roadmaster. The rusty pieces slip into brackets that are attached to the frame of the car. Those brackets are part of the "base plate" and without the brackets that were left on the car the stuff you have is basically worthless unless you find someone with same type car that had a front-end collision and bent up their tow bar brackets.
Lee
Yes. That makes sense. I won't use them, but I thought if I knew what they were, I could at least advertise them availible to anyone who would want to arrange to get them. Maybe I'll send the picture to Roadmaster with the question. I hate to dump them in the scrap steel bin if they will help someone out.
Do you think they are worth the effort? Are they safe? I just don't know Roadmaster at all.
They are valuable. Either hang on to them for future use or find someone that needs them.
I think those are the universal parts that mate up to the custom receivers that ount on the vehicle chassis.
Yes, they look like Roadmaster parts. The parts with the square tubing slide into receivers that are permanently mounted to a toad, generally somewhat hidden. The long part then drops onto those parts and the folding tow bar is mounted to it with heavy bolts.
That way when the toad is not being used as a toad the folding tow bar can be removed.
I have seen a trend however to where the tow bar is attached to the coach using the coach hitch receiver, and the tow bar then attaches to attach points on the toad. That way the toad never has a tow bar folded on its front. The tow bar is stowed by folding it against the rear bumper of the bus.
Bring them with you to Spearfish. If you do not want them somebody might. Personally I prefer that method to the one in which the two bar folds against the bus rear bumper.
Dust Man,
Here is what Jon's talking about. I had several of these and you either have the one as pictured that attaches to the 2" ball on your receiver or the one that is actually the receiver itself and eliminates the 2" ball.
The parts in the picture are the only parts I have. They were left by the previous owner. Being the nit picker that I am at times, I will clean and paint these and hold for someone who can use them. I will be ordering the Blue Ox Aventa LX Tow Bar today.
