I just rinsed it off with water. Gary said he wiped his off with a cloth.
I put the stuff on wearing a pair of latex gloves. Gary said he wiped his on with his Johnson.
I washed my coach before. Gary washed his after.
I put the coach condom on. Gary did his au natural.
I wash the windows on my coach myself. Jon has the King of Bling wash his.
Pork and Beef BBQ will do that Truk. Sheep will not, so you are okay.
King, tacos mess it up from the inside. Wake up for crying out loud.
I didn't know there was window etiquette! Once again Jdub sets the standard.
I use Plastx on a new white foam pad. Apply the polish with a small orbital buffer running at medium speed. Takes off everything that is on glass.
I had a trail of hard water stain from roof run off. All clean in a couple passes. After I cleaned the windows I went over the glass with the Solution quick detailer.
Lots of plastic polish on the market and no end to quick detailer products, they probably all work in this application.
http://meguiarsdirect.com/detail/MEG+G12310
