A Couple of Question??
One!
When I am standing at the rear of my coach, looking into the engine compartment, what does the gauge on the left monitor (see attached picture). It looks like a sending unit or pressure switch, but I not sure what it is monitoring? Is this a local oil pressure gauge and sending unit? Any ideas?
What does the gauge on the left monitor?
I looks like the gauge in broken, it reads 20 psi all the time.
The gauge on the left is engine coolant temperature. It follows the coolant temperature of the engine fairly closely.
Two!
Also, concerning the Prevost dash air. When I monitor the duct outlet temperature, I get readings of 58 - 60 degrees. My compressor suction pressure is 37 - 39 psi and the discharge pressure is 160 -175. I am running a R-12 system. I see these pressures after fast idling for 15 minutes and the system is stable. With little experience with Prevost A/C systems, is this 'as good as it gets'? My Country Coach bus air works great. Duct discharge temperatures run 45 - 50 degrees. Any A/C experts out there? Are these normal parameters?
Hector
