Hi Ed. Help me out here, what am I looking at?
every mechanic should be able to identify this procedure
Positive it is a muffler bearing
Its been a very long time since I heard that expression.
The reason for that repair is (as anyone can see) that the grease fitting was not installed.
Tops on my list is the failure of just about every Prevost owner to change the air in their tires.
It appears to me that the repair is still in progress, meaning someone is installing the new muffler bearing, not removing the old. Further, it also appears that the mechanic is gambling with an oversized bearing rather than using the recommended Timken 452-544-A1 bearing, the installer is using the A4 Timken. Also, by the appearance, the bearing has not been allowed to soak the manufacturer advised 10 day period in brine...which, of course explains the lack of a zerk fitting!!
Personally, I never change air in my tires, long ago I determined that it was much more viable to "rotate the air"....I take the air from the left front and put it in the right rear and so on. Takes a bit more time but well worth it!
Is that the turdbulator from JDUB's plane?
Roger that!
2008 Liberty DS XL2
2023 Denali Ultimate
My 6th Prevost
What is the proper method of disposing of the "old" air that was in the tires?
Should it be put in a hermitically sealed plastic barrel and brought to a certified disposal facility that is located in the California desert?
How much should be paid to Al Gore for the carbon footprint that the "contaminated air" has caused to the environment.
I think that I am just going to quit driving. It is causing too much damage to our ecosystem.
Tuga & Karen Gaidry
2012 Honda Pilot
Looks to me like a bearing off a sisse wheel from a tumbling shaft. Parts left over from a Smith Power Products Inc. overhaul.
Harry
Shirley & Harry / 2000 Liberty / 2008 GMC Envoy Denali
