Had this stuff Laying around the garage since we bought this truck 10 yrs. ago. Finally got them on today.
The location for the stock spin on filter on the lower rear of a Dodge 318 V-8.
Now replaced by this.
2 kits here-First is an engine oil cooler adapter and then a remote filter adapter screwed into it (you can see them laying seperate on the table in the first picture, lower right). They both were supposed to have 2 lines for each but I plugged the return on the cooler and plugged the supply on the remote filter attatchment, plumbed them in line and was able to eliminate 2 of the 4 hoses. It flows out of the engine to the filters first then through the cooler and back.
This pic. is right behind the right headlight, the inside fender. There is a Oil Temp. sensor plumbed into this housing and I've got some Stewart-Warner Engine & Trans Oil Temp. gauges in pods on the A-Post in the cab
Upped the oil Capacity to 7&1/2 qts.
Got some black plastic loom guard to put on the hoses after making sure everything is not leaking and I'll do that and zip tie everything tomorrow.
