Results 1 to 10 of 34
Thread: power steering
    I suggested lifting the tag to take a little weight off the front axle so when it does not work in close quarters the effort to turn the wheel will not be as great.
    I don't think the ride height affects the power steering. The front ride height definitely affects handling, but I can't imagine the power steering would be disabled if the bus is up or down.
    After driving all day, I turned off my engine to go inside to register at an RV Park. When I came back out and fired up the Coach, my power steering did not work. I moved the Coach forward 20 or so feet and suddenly it worked. That was almost two years ago and I have not had the problem again. I guess it was a hic up with the pump, or the fluid was too hot, or some other one time event.
    Petervs Guest
    Interesting subject. I think we all agree it should not operate this way. Something is amiss.
    Lifting the tag would be a stopgap measure to help move the coach only, not a correct way to solve this problem.
    When you lift the tag the steering should get easier because the weight on the front axle decreases by about 10% ( do the math...it is not a significant amount in my opinion), and more so because the turning radius becomes better because the effective wheelbase is shorter, and there is less "squirming" of the tires in the back.
    When you first start the engine, maybe the belt is slipping that drives the power steering pump? Maybe the pneumatic belt tensioner has not come up to pressure yet? maybe the belt or pulley is worn?
    I would go back and look at the engine while it is running when the power steering is not operating correctly, you might learn a lot!
    You could "work" the power steering a bit by just turning the wheel back and forth with the bus not moving to see if it gets going.
    Did you try shutting it off and restarting and did you try waiting longer?
    I am surprised that they changed these things over to belt from gear driven???????????
    Maybe it has an air pocket.
    3,782
    It's gear driven unless they made a big change. Don't forget the more obvious possibility, air in the system. There is a procedure to purge out the air, but I don't remember the details.
    Petervs Guest
    Yes of course it is gear driven. I guess I was thinking itsy bitsy little vehicles.
    Anyway, the Prevost Car website has the instructions for troubleshooting and bleeding the system.
    http://technicalpublications.prevost.../en/manuel.asp
    Choose your model coach and year, click on technical publications, and then chapter 14, steering.
    Good luck, and tell us what you find out to solve this problem.
    Dec 2006
    442
    thanks for all the info, I haven't been out there yet....I'll report back
    Wendy and Rick DeSilva
    '08 Marathon H-3
    2017 F350 platinum
    Mahwah, NJ
    Brant Beach, NJ
    Pelican Lake, Fla
    Jun 2017
    Spencerville
    41
    The LINK to the Prevost page for the PS no longer works! Anyone able to update it site location?
  1. Power Steering Fluid Question
    By hobobimmer in forum Engines, transmissions, axles and wheels
    Last Post: 08-27-2009, 09:27 AM
  2. Where is the power steering reservoir?
    Last Post: 09-26-2008, 08:10 PM
  3. Howard Power Center Steering
    Last Post: 07-17-2008, 03:05 PM
  4. Howard Power Steering
    By traveling.dude in forum Prevost Shells and Prevost Car Company
    Last Post: 04-25-2008, 08:07 AM
  5. Power Steering Filter
    By truk4u in forum WANT/NEED PARTS?
    Last Post: 07-12-2006, 11:04 PM
