For those of us Po' Folks who figured that a Series 60 was something that only the Prevost Prouds could afford, we might have thought that just having the newer engine was the be-all and end-all.
Waaalll, turns out that the first years of the Series 60 were not without some, well, problems.
The serpentine belt (very important) had problems in keeping a crown on the pulleys and there was some disagreement about belt tensioning. There was originally a screw-type tensioner. The idea here was to use some kind of a flapper gauge (very inaccurate) to determine belt slap. If the belt weren't completely set to the crown of the pulleys, side wear on the wide belt would result (bad).
So, there's an upgrade.
The oil refill housing is replaced, with the 2 silver pulleys and a spring-loaded belt tensioner. The mechanic here put chalk marks on the side of the belt prior to the test drive to insure that the belt was not rubbing on the site of the pulleys.
Just looking at it, I would guess that this upgrade in DD land is probably around $1200 off the shelf+labor. It is likely that the W.W. Grainger crowd could find some alternatives.
What this dealie does is regulate the tension on the serpentine belt accurately, even with increased heat, etc.
It's about a one-hour job to install the upgrade and you throw away the older threaded bolt tensioner (or send it to a friend).
Oh, a reminder, with the upgrade, you'll need a different belt than the one you used before as the upgrade kit requires a longer belt.
