I started to think about the gearbox that runs the cooling fan. I was looking at it and noticed there was no way to check the oil level and no way to drain it. I had called Prevost and they said they made a dipstick from a piece of wire. I made one and check the level, it was half full.
I thought that maybe I should just drain and replace the oil. If you couldn’t access the drain plug then maybe it had never been serviced since it was put in. I looked for a drain plug and didn’t find one. What they did was put the gearbox on a riser with no way to drain the oil. I used a suction method to remove the oil.
While working on removing the oil, I thought maybe I should just remove the riser and cut a hole in it and add a extension tube to the drain. It looks like it will be much easier to service the gearbox now.
If you are using a 200 series gearbox made by Superior you might want to make this modification.
