Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Light Replacement
    Nov 2006
    Huntsville
    3,135
    Default Light Replacement
    I need to replace either the light or the shade on the light in my shower. I've looked at several local RV shops with no results. I've also searched the internet with no luck. Does anyone know of a good source for RV lights? The diameter of the light is about 5 1/2" at the base.
    Dale & Paulette
    Apr 2006
    Battle Ground, WA
    851
    Dale,
    You might start with sending your photo to the parts dept at CC. Much of the hardware they use on their conversions comes from the plastic side.
    Mar 2006
    Santa Barbara
    3,177
    Check out Campingworld or just a local RV repair shop. Should be easy to find.
    Nov 2006
    Huntsville
    3,135
    I checked with Camping World and all the local shops, and they don't have anything close. Since I made the post, I've found a couple on eBay that apper to be very close. If I can't get the exact replacement from CC, I'll try one of the eBay units.
    Dale & Paulette
    Orren Zook Guest
    There are a couple of places in Elkhart IN and one in Madison OH that deal in current and surplus RV components - I'll get you the contact info when I get to work in the AM
    May 2007
    Port St. Lucie, FL
    1,745
    Your light looks a lot like some I've seen tn marine supply stores, such as West Marine.
    Might be worth a check....
    Sep 2007
    467
    Dale,
    It is made by Sealand. Check out any marine store. When you will mount it back, keep the brass ring loose if not the glass lens will crack.
    Alek
    Nov 2006
    Huntsville
    3,135
    I had checked with our local West Marine, but they didn't have one. Country Coach is trying to get it for me. Alek, I think you are right that the lens cracked from being too tight.
    Dale & Paulette
    Sep 2007
    467
    Dale,
    The name of the supplier is: http://www.sea-dog.com
    not sealand,
    Sorry.
    Nov 2006
    Huntsville
    3,135
    I was pleasantly surprised that Country Coach called back yesterday , and they are sending me an exact replacement for $20 plus shipping. That is less than a similar one I saw on eBay.
    Dale & Paulette
  1. ABS LIGHT
    By Jamie Bradford in forum Engines, transmissions, axles and wheels
    Last Post: 02-19-2010, 09:11 PM
  2. Entry light replacement?
    By sawdust_128 in forum WHERE TO FIND STUFF: Links and Resources
    Last Post: 12-09-2008, 01:49 AM
  3. HI-LO Battery Light
    By tdelorme in forum Ah Houston, I think we have a problem...
    Last Post: 09-12-2008, 09:08 AM
  4. Light Problem
    Last Post: 04-07-2008, 11:50 PM
  5. Rope Light Replacement, It's Easy!
    By dreamchasers in forum Sparky's Corner
    Last Post: 03-07-2008, 08:40 AM
