Originally Posted by
Gary & Peggy Stevens
Larry W., thanks for the insite into the Hot / Cold water system in the Aqua Hot systems. I had to send your information on to a friend of mine that is complaining about his 04 CC Magna, and their cold showers.
I am sure he will appreciate your insite to this problem.
Thanks from both of us.
Gary S.
Gary,
I learned a little trick from JDUB @ Santa Fe rally about the Aqua Hot. When the CG water is very cold try filling your fresh water tank about 24 hours BEFORE you shower. Turn the heating thermostat in your bay up to about 70degrees and let the CG water warm up to about 70 degrees; this will give you a longer hot shower. The Aqua Hot can warm up water about 45 degrees; so 45 degree water coming out of the ground can only be heated to about 90 degrees, which makes for a cool shower. I tried this method of advanced filling and it works great.
Tuga & Karen Gaidry
2012 Honda Pilot
