My Country Coach has a sliding, mirror covered, pocket door for the commode area. When I slide the door closed, the door guide (Located in the door lock mechanism, does not line up with the receiving round slot in the lock receiver mounted on the door frame (Whew!)). Under normal circumstances, simply adjusting the nut on one of the roller hangers would align things up. In this installation, the pocket door apprears to have been installed and the coach built around it. The only room to get a wrench to the adjusting hanger is above the door, through the 1 1/2 inch slot the pocket door in built in, then up 1 1/2 inches, then back 2 inches. #$%##
Question: What is the secret for adjusting this guy? Is their a special tool needed? Can I buy it or make it?
I hope the answer is not to remove parts of the ceiling to get access. OK, you Country Coach owners, How about it?
Hector
