Results 51 to 51 of 51
Thread: Webasto Valves
Threaded View
    Mar 2007
    Reno, Nevada
    237
    Default Webasto Valves
    Finally took the time to figure out how my Webasto system works. This coach has three switches that cause the Webasto to fire off.
    1) On the Marathon dash there is a switch call 'System Heat'. When this switch is pushed the Webasto fires and the small pump inside the Webasto circulates hot water through the two 10 gallon water heaters and now we have hot water.
    2) There is a switch in the main electrical panel in the rear (bedroom) that says '12 Volt Water Heater'. Push that switch and the exact same thing happens as in #1. Interesting?
    3) There is another switch in the main electrical panel in the rear (bedroom) that says '12 Volt Heat'. When this switch is pushed the Webasto fires and the small pump inside the Webasto circulates hot water through the two 10 gallon water heaters. Also, if any of the three heat exchangers in the coach that use the hot water for heat are calling for heat a solenoid valve opens and another aux pump in the spare tire area turns on which circulates hot water through all three of the interior heat exchangers. Now we can heat the inside of the coach. Nice!
    That left me with only one more thing to figure out, how does the Webasto pre heat the engine. Well, after hunting all around I finally determined that in this coach the Webasto does NOT pre heat the engine. The Webasto system picks up and delivers coolant to the line that connects the coolant surge tank to the water pump (engine). By pure coincidence some of the heated coolant makes it down to the Water pump and warms it up. This was real informative beacause for the last year I believed the Webasto pre heated the engine.
    All is not lost as the coach is equiped with a 120 volt block heater which works good. Mystery solved.
    Below are a couple pictures of the three valves located at the Webasto unit. I'd like to confirm that these are just solenoid valves and not pumps?
  1. Webasto heat control valves
    By phorner in forum Busted Knuckles and Greasy Jeans
    Last Post: 08-19-2018, 04:43 PM
  2. Webasto
    By JIM CHALOUPKA in forum Busted Knuckles and Greasy Jeans
    Last Post: 01-12-2009, 09:56 PM
  3. Webasto
    By adamdegraff in forum Busted Knuckles and Greasy Jeans
    Last Post: 11-17-2008, 07:15 PM
  4. Webasto Help
    By Jim_Scoggins in forum WHERE TO FIND STUFF: Links and Resources
    Last Post: 12-15-2007, 06:06 AM
  5. Replacing Level Low Valves
    By MangoMike in forum Busted Knuckles and Greasy Jeans
    Last Post: 11-26-2006, 10:13 AM
