For the next 2.5 weeks the bus will be parked here in Nova Scotia. To avoid frozen pipes, what should we keep running.
The bus is plugged into 15 amp house connection. I currently have the galley webasto set to 55 degrees. I have the basement heater set above freezing.
How much diesel will it use over the 2.5 weeks with freezing temperatures most days?
Also, I purchased two digital thermostats to replace the two White-??? thermostats that control the CC/Webasto system. Is there any reason I should not instal them?
Thanks.
