Results 1 to 4 of 4
Thread: Fuel Filters
    Nichols Hills
    2,465
    Thumbs up Fuel Filters
    After the return trip from POG UNO, we developed a small power issue between Lake Charles, LA and Beaumont, TX. The coach would run 70mph on flat ground, but when we started to pull a hill, it would slow down to the lower 60's.
    This was abnormal in that it never slows up more than a 1 or 2 mph unless the grade is really steep. I suspected the fuel filters.
    There may have been a couple of mitigating circumstances, but I had done something I rarely do; ran the tank down to around 1/8th full. I knew I was going to stop at the Flying J near Beaumont and I had plenty of fuel to get there. I will also say we bought fuel south of Lake City on I-75 just before we got on I-10, so we had been a bunch of miles before this became an issue.
    I think part of my problem stemmed from having the fuel level that low and driving across an extremely rough section of I-10. The sloshing must have stirred up sediment / water in the bottom of the tank as the primary filter (Racor 1000FF Turbine Separator) had an inordinate amount of water in it and the filter was covered in crud. This is a Racor 2020 30 micron fuel filter element.
    I changed both the primary and secondary yesterday and the engine is running normally with plenty of power. During the restricted fuel flow driving, the turbo boost would max around 12 to 13. It runs 15 now.
    I know I am not the first one to experience this, but I you need to have both of those filters IN YOUR COACH unless you want to experience a potential unwanted delay or problem. Regardless of if you change them or you get someone to do it, not being able to get the filters out in the middle of BFE Arkansas in the evening on Sunday will be the issue.
    They are not hard to change and you need to make sure you fill them when you change them and the Racor filter holds a lot of diesel. Having an empty gallon oil jug with you to fill full of diesel is a good idea.
    And don't forget to write the mileage and date on the filter with a Sharpie.
    There is another thing to consider. First, Jerry is absolutely correct about the need to carry spare filters. At the first sign of the engine shuddering or slowing down you need to find a truck stop and be able to access the fueling island.
    You have not lived until you have run your bus out of fuel. I am not suggesting you have run the tank dry, just that you have clogged filters such that fuel stops getting to the engine.
    Can you imagine doing this along side of the interstate?
    When you change fuel filters it is imperative that you fill them to overflowing with fresh fuel (hence the need to be near a source of fuel). Depending on your coach and the equipment in your fuel system it may take more fuel than you can carry in a gallon jug. My old Liberty had two spin on filters and the big Racor Jerry talked about. If you have never changed your filters or are unfamiliar with the process there is an article on this under information sharing.
    3,775
    Jerry,
    Was it buggy in BFE Arkansas?
    Nichols Hills
    2,465
    Don't you know it
    I used to live in Fort Smith, so I feel completely comfortable / qualified telling Arkansas jokes. I feel I earned the right. And I still have all my own teeth
  1. What filters are these?
    By gmcbuffalo in forum Busted Knuckles and Greasy Jeans
    Last Post: 04-29-2009, 09:11 PM
  2. Filters
    Last Post: 04-29-2009, 03:43 PM
  3. Fuel Filters
    Last Post: 01-19-2009, 10:36 PM
  4. Fluids 'n Filters
    By phorner in forum Busted Knuckles and Greasy Jeans
    Last Post: 07-26-2008, 09:37 PM
  5. Racor Fuel Filters
    By JIM KELLER in forum Busted Knuckles and Greasy Jeans
    Last Post: 07-11-2007, 03:12 PM
