Is it possible to blow out a tire ( the sidewall) by merely rubbing against a curb at low speed while cornering?
Granvil Tracy
2000 Vantare XLV45, S-2
I am not exactly sure we are talking about the same thing, but yes it is often done but trucks, I have witnessed the event numerous times. It usually happens with a fully loaded flat bed trailer when the turn was not setup properly and a rear wheel hits the curb just right and because the trailer weighs so much that it can't be pushed sideways the tire gives, and the seal between the rim and the bead are broken and with a bang all the air rushes out.
The sidewalls are thin and rubbing them are the achilles heal of the tire if there is one. Any time you rub one there is cause for concern. I'm not refering to the seal at the bead.
Granvil, Who was driving, you or the Diesel Dyke ?
99 Country Coach 45XL
Jeep Liberty
it was a joint effort.
Granvil Tracy
What was your altitude when Kim hit the curb?
Wendy and Rick DeSilva
'08 Marathon H-3
2017 F350 platinum
Mahwah, NJ
Brant Beach, NJ
Pelican Lake, Fla
