Results 1 to 7 of 7
Thread: New use for old air springs!
Hybrid View
    dalej Guest
    Default New use for old air springs!
    While working on the install of the shocks/air-springs I came up with this idea for my old air-springs.
    My son wanted one for his garage after I raised one side of his truck in five seconds.
    Notes: If you push all the air out of the bag and then put your finger over the fill hole, it keep the bag deflated utill in place. You could put a shut off valve at the elbow if you want.
    Joe Cannarozzi Guest
    Dale that is very slick. A couple of small wheels and a handle would make good additions to the idea.
    How do you regulate the height?
    Alexandria
    2,161
    Dale,
    Plus a lot cheaper than the $159 they want on ebay.
    Good to see you going green and recycling. Helps to make up for your fuel sins.
    mm
    Mar 2006
    ON THE ROAD IN THE SOUTH
    2,825
    Default Real Nice
    Dale, that gives new meaning to the words AIR UP
    Why stop there, Dale. We already know they will support the coach. What better way to lift an axle to change a tire?
    dalej Guest
    Jon, I know, but remember I bought the air/hyd. 20 ton, I better use it or Jan will think I wasted $70
  1. gas springs for bay doors
    By ken&ellen in forum WANT/NEED PARTS?
    Last Post: 12-31-2009, 07:47 PM
  2. Crystal Springs, Nevada
    By phorner in forum On the Lighter Side...
    Last Post: 09-16-2009, 05:18 PM
  3. Air Springs Revisited
    By BrianE in forum On The Level
    Last Post: 02-20-2009, 07:12 AM
  4. replacement air springs
    By bluevost in forum On The Level
    Last Post: 02-11-2009, 09:59 PM
  5. Weak Bay Door Air Springs
    By win42 in forum WHERE TO FIND STUFF: Links and Resources
    Last Post: 04-02-2007, 02:08 PM
