Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Tools...You Say?
    Just Plain Jeff Guest
    Default Tools...You Say?
    It would seem that this winter many POG members, and their identities need not be specific, are spending way too much time on the internet and not enough time with in their shop/garages. Here's a refresher course:
    TOOL DEFINITIONS
    DRILL PRESS: A tall upright machine useful for suddenly snatching
    flat metal bar stock out of your hands, so it smacks you in the chest
    and flings your beer across the room, splattering it against that
    freshly stained, heirloom piece you were drying.
    WIRE WHEEL: Cleans paint off bolts and then throws them somewhere
    under the workbench with the speed of light. Also removes
    fingerprints and hard-earned guitar calluses from fingers in about
    the time it takes you to say, "Yeou shit...."
    ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
    holes until you die of old age.
    SKILL SAW: A portable cutting tool used to make studs too short.
    PLIERS: Used to round off bolt heads. Sometimes used in the creation
    of blood blisters. The tool used most often by all women.
    BELT SANDER: An electric sanding tool commonly used to convert minor
    touchup jobs into major refinishing jobs.
    HACKSAW: One of a family of cutting tools built on the Ouija board
    principle. It transforms human energy into a crooked, unpredictable
    motion, and the more you attempt to influence its course, the more
    dismal your future becomes.
    VISE-GRIPS: Generally used after pliers to completely round off bolt
    heads. If nothing else is available, they can also be used to
    transfer intense welding heat to the palm of your hand.
    WELDING GLOVES: Heavy-duty leather gloves used to prolong the
    conduction of intense welding heat to the palm of your hand.
    OXYACETYLENE TORCH: Used almost entirely for lighting various
    flammable objects in your shop on fire. Also handy for igniting the
    grease inside the wheel hub that you want the bearing race out of.
    WHITWORTH SOCKETS: Once used for working on older British cars and
    motorcycles, they are now used mainly for impersonating that 9/16 or
    ½ socket you've been searching for the last 45 minutes.
    TABLE SAW: A large, stationary power tool commonly used to launch
    wood projectiles for testing wall integrity.
    HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground
    after you have installed your new brake shoes, trapping the jack
    handle firmly under the bumper.
    EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an automobile
    upward off of a trapped hydraulic jack handle.
    TWEEZERS: A tool for removing wood splinters and wire wheel wires.
    E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any
    known drill bit that snaps neatly off in bolt holes, thereby ending
    any possible future use.
    RADIAL ARM SAW: A large, stationary power saw primarily used by most
    shops to scare neophytes into choosing another line of work.
    TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength
    of everything you forgot to disconnect.
    CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that
    inexplicably has an accurately machined screwdriver tip on the end
    opposite the handle.
    AVIATION METAL SNIPS: See hacksaw.
    TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes
    called a drop light, it is a good source of vitamin D, "the sunshine
    vitamin," which is not otherwise found under cars at night. Health
    benefits aside, its main purpose is to consume 40-watt light bulbs at
    about the same rate that 105mm howitzer shells might be used during,
    say, the first few hours of the Battle of the Bulge. More often dark
    than light, its name is somewhat misleading.
    PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under
    lids and for opening old-style paper-and-tin oil cans and splashing
    oil on your shirt; but can also be used, as the name implies, to
    strip out Phillips screw heads. Women excel at using this tool.
    STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used
    to convert common slotted screws into non-removable screws.
    AIR COMPRESSOR: A machine that takes energy produced in a coal-
    burning power plant 200 miles away and transforms it into compressed
    air that travels by hose to a Chicago Pneumatic impact wrench that
    grips rusty bolts which were last over tightened 30 years ago by
    someone at Ford, and instantly rounds off their heads. Also used to
    quickly snap off lug nuts.
    PRY BAR: A tool used to crumple the metal surrounding that clip or
    bracket you needed to remove in order to replace a 50 cent part.
    HOSE CUTTER: A tool used to make hoses too short.
    HAMMER: Originally employed as a weapon of war, the hammer nowadays
    is used as a kind of divining rod to locate the most expensive parts
    adjacent the object we are trying to hit. Women primarily use it to
    make gaping holes in walls when hanging pictures.
    MECHANIC'S KNIFE: Used to open and slice through the contents of
    cardboard cartons delivered to your front door; works particularly
    well on contents such as seats, vinyl records, liquids in plastic
    bottles, collector magazines, refund checks, and rubber or plastic
    parts. Especially useful for slicing work clothes, but only while in
    use.
    Jasper
    3,775
    Well folks, it finally happened! The sub-zero temperatures, the lack of fresh out of the water lobster at the corner fishy place, tree sap frozen, moose with icicles hanging off their noses, the wood supply for the stove frozen in the yard, the diesel pick-up that won't start since the fuel jelled and no sunshine since November has finally made him snap.
    Lets all take a collection to send JPJ to Lakeland for a few days of R & R so he can drop to his knees and hug the sun warmed front bumper of his vintage 84 Preeeeyyyyyyyyvooooosssssttttttt.
    Anaheim
    566
    HOLLY S__T, someone has way to much time on there hands. JPJ, I could use a little help with the camper, what time should I expect you?
    Well, doesn't it sound like the Trukster hit the 'shine early tonight?
    Anyway, I'm always game for wood in the camper Kevin. Got a Sawzall, duct tape and plywood. Geez, a guy can fix just about anything with that, given enough drywall screws, huh?
    Let's git 'er done!
    Mar 2006
    ON THE ROAD IN THE SOUTH
    2,825
    Jeff, I think you've been spending too much time alone in your shop!
    Hey Jim:
    How's that camper search going?
    Nov 2006
    Sugar Land, TX
    1,307
    Default N B C
    Hey Jim, I hate to do this to you, BUT I can now.
    You must be an honorary single member of N B C
    NO BUS CLUB
    Sorry Jim, but everybody was already thinking this, and I am just damn glad I am not a member anymore. You better get moving on that Perfect Bus
    Mar 2006
    2,825
    Wink You Always Hurt The One You Love
    Well Gary I'm the only one to admit to it.
    My day will come, or was that a song
    You are not the only one to admit it Jim, but if things keep going the way they have been you may be the only lifetime member. All the others are actually kicking tires.
    dalej Guest
    And don't forget Jim, you sent that pizza to Florida, that was worth more then you owning a bus!
  1. Camp Tools... Must have
    By jello_jeep in forum On the Lighter Side...
    Last Post: 08-04-2009, 09:13 PM
  2. Tools and stuff....
    By dalej in forum MISCELLANEOUS ITEMS
    Last Post: 05-13-2009, 11:21 PM
  3. Why Men NEED Tools!
    By Just Plain Jeff in forum MISCELLANEOUS ITEMS
    Last Post: 06-08-2007, 02:32 PM
  4. Tools!!!
    By jello_jeep in forum Busted Knuckles and Greasy Jeans
    Last Post: 12-13-2006, 12:09 PM
  5. What tools do I need?
    By dreadnought in forum Busted Knuckles and Greasy Jeans
    Last Post: 10-29-2006, 09:36 PM
