Page 7 of 7 FirstFirst ... 567
Results 61 to 66 of 66
Thread: Led Tail Lights
  1. #61
    Orren Zook Guest
    Quote Originally Posted by Tully View Post
    Looked at the Grote site. Looks like the metal protector bracket that goes around my current lights will not fit.What type of bracket or cover did you use? Tully
    Grote also makes a 24v lamp with a standard wire connector that does not require a special pigtail, and you're right - the chrome branch deflector won't fit but, you can use the existing mounting holes and wire connector that Prevost uses. I just went around the (white) base with black plastic edge molding. I'll post a picture for you in the AM.
  2. #62
    May 2008
    Peabody, MA
    112
    I think IBP sells the same Grote 24V markers for about $25 each...
    You will need 2 8-32 well nuts for each marker. I got them here:
    http://www.ribetproducts.com/product...7&cat=0&page=1
    I got the bullet connectors at Ryder as well - part number V84 12267. The Grote pigtail uses a .180" bullet instead of the more common .157".
    The local hardware store was the source for the 8-32 machine screws. I'll take some pictures and post them tomorrow, as well as get the length of the screws.
    Steve
  3. #63
    Tully Guest
    Thanks Steve,
    Tully
  4. #64
    May 2008
    Peabody, MA
    112
    Here's what the Grote lights look like...
  5. #65
    May 2008
    Peabody, MA
    112
    Here's what the pigtails look like under the markers. The screws I used were 8-32 1 1/2".
  6. #66
    Tully Guest
    Thanks for posting the pic's Steve. Got a better idea on the pigtail.
    Tully
  1. Muffler Tail Pipe
    By truk4u in forum WANT/NEED PARTS?
    Last Post: 11-16-2011, 05:20 PM
  2. Built in Tail light converter
    By Devin W in forum TOADS, TRAILERS & TOYS
    Last Post: 01-06-2010, 08:43 PM
  3. Tail of the Dragon
    By Jon Wehrenberg in forum RALLIES AND GET-TOGETHERS
    Last Post: 04-29-2008, 01:03 PM
  4. Tail & Marker Lights For Sale
    By BrianE in forum PARTS AND PIECES FOR SALE OR TRADE
    Last Post: 01-30-2007, 10:20 PM
  5. LED Tail Lights - Let the Bling Begin
    By Jerry Winchester in forum WANT/NEED PARTS?
    Last Post: 07-29-2006, 05:47 PM
