Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: Preventive Maintenance
    Apr 2006
    Battle Ground, WA
    851
    Default Preventive Maintenance
    At 14 years and 115K miles I figured it was about time for some preventive inspection and upgrades. Thanks to Prevost's excellent Maintenance Manual and the very helpful articles posted primarily by Jon and Mango Mike, the job was easy, a little dirty but hey, the accumulated oil and grease kept it from rusting. The job was aided by the fact that I've got a nice place to work, a reasonable set of tools, a set of air/oil jacks and 1" impact wrench from Harbor Freight, and a great assistant. Thanks again to Mikes site and various posts for the tool tips. Jon's new stands would have been nice but the blocks I borrowed from Petervs worked just fine. Would recommend the project to anyone who has a decent place to work on their bus and who doesn't mind getting their hands dirty (disposable gloves and coveralls are almost a necessity).
    Included in the project were removing the wheels for ease of access, a good cleaning and inspection of brakes and suspension, and the replacement of all the flexible brake hoses, brake chambers, shocks and airbags. After the work was completed it was dead simple to do a good soap bottle/ultrasonic leak check of air lines, couplings, and Norgren valves with the wheels off.
    Inside the bus we removed the electric Cadet and Wabasto heaters for cleaning and inspection. The Webasto heater motors were all badly worn and have been replaced along with their respective heater hoses. In some ways this was a worse job than the heavy external stuff.
    By the way, the tidy floor, daily tool pickup and numerous other nasty chores were done by Beverly who actually enjoys helping in the bus barn and who now knows the difference between a quick release valve and a leveling valve. She ain't bad behind the wheel either.
    Alexandria
    2,161
    Brian,
    I posted your pix for the Mango's kitchen team saying that I wanted our floors to look as good. Nice job.
    mm
    dalej Guest
    Looks fun Brian, wished we could do that at a rally, it's a very good way to see what's going on under one's bus.
    Brian,
    Outstanding job. As more guys do this even more guys will realize how much work we can easily do on our coaches and how enjoyable it is having the confidence of knowing what is under the bus and what makes it tick.
    Do you agree with our 1 to 1.5 hours per air bag estimate?
    Did you replace the front air bags by modifying the front plumbing a little?
    If it is not too late, look up at the two copper pipes on the driver's side that run tight to the underside of the floor towards the front. Where they go into the bulkhead in front of the drive axle are two short sections of rubber hose connecting the copper pipes to the forward copper pipes. Those rubber hoses do not age well. If your project includes changing coolant, I would urge you to replace those rubber hose sections, plus any others you can find throughout the entire coach. That is the least satisfying project I have done, and it took about a day to find, remove and replace them all on my old coach, but they are as critical as the work you completed. I had an on road failure of a hose section, and Joe recently had a split hose both due to age.
    Feb 2006
    Bristol, Tn
    1,647
    Brian: WOW. We, --no make that I need a class from Beverly on how to keep my floor that clean when working on the bus. I am impressed.
    Roger that!
    2008 Liberty DS XL2
    2023 Denali Ultimate
    My 6th Prevost
    Jul 2007
    East Texas
    946
    Thumbs up WOW, nice Floor
    That is a real nice floor in your bus barn, Brian. Will you share with us what the finish is. I was going to use concrete stain on mine, but I sure like the looks of yours.
    Another quick question. The little doors between the drive and tag. Do you use yours? My latches are just about worn out and no matter how much adjusting I do they still pop open every now and then. I'm thinking I'll just turn the latch sideways and keep them closed but if there is a good fix I sure would like to know. Thanks
    Joe Cannarozzi Guest
    Ted ours flips up, the hindge is at the top, so I guess there are a couple different types. It is for storage for the waste hose, a piece of 4in. white PVC is behind ours.
    Mar 2006
    ON THE ROAD IN THE SOUTH
    2,825
    Thumbs up
    Sure looks nice there Brian, all neatly laid out as though for a TV how to show.
    It looks like there are a couple large Snapon tool boxes reflected in the SS.
    Nichols Hills
    2,465
    Default Maintenance O'Plenty
    I scooted down to Birdland Coach here in Houston today and who's coach was there getting some preventive maintenance?
    Yep, the Loc Ness Millennium.
    A group of smartly attired service technicians were on the roof removing the awning so they could install some strategically placed drain holes.
    Loc, this one is a little jagged, but I think it will drain okay......
    Brian,
    Way nice job on your rig. How about some more pics?
    Jerry where did you get that picture? What numbskull would have done something like that
    P.S. I got more, lots more
  1. maintenance.xls log
    By lloyd&pamela in forum Busted Knuckles and Greasy Jeans
    Last Post: 08-03-2009, 06:05 PM
  2. Maintenance Tip
    By sawdust_128 in forum Busted Knuckles and Greasy Jeans
    Last Post: 11-25-2008, 07:32 PM
  3. Post Preventive Maintenance
    Last Post: 11-16-2008, 05:30 PM
  4. Roof AC Maintenance
    Last Post: 10-22-2008, 05:14 PM
  5. Engine maintenance
    By rbeecher in forum Engines, transmissions, axles and wheels
    Last Post: 03-15-2007, 11:49 AM
