Are the 2 110 outlets above the engine at the back door for general use? Only hot when block heater is on. Does this mean if I put block heater circuit breaker on that I am heating the block? Are does the block heater plug in one of these outlets? I want to use one for battery tender without heating block as I am in the promise land of So. Ms. where it is 80 degrees!!! Dan
