Here is a little Webasto info from a guy who lives and camps in Alaska. I shared with him Mango Mikes stuff on Webasto. Thanks Mike.
He sent the following which might help one of us some day.
It looks like the gremlins have all moved north for the duration. On the
way back from Haines it was the Facet (which has worked perfectly since we
got back) and now the Webasto. Dewey came out this morning to see what the
problem was, even brought a new reset switch in case mine was bad. He
pushed the reset and it clicked. I turned on the Webasto and it fired right
up.
I just about wore my finger out on the reset at Eureka and also tried it
again after we got back to Anchorage with no luck whatsoever. I did find
out what the reset is though. It is an impact switch which trips in an
accident to shut off fuel to the Webasto. Just like an ELT I had in my
Helio, a bump can cause it to close. The only think I can figure is that
it somehow hung up because the heater worked all night although it didn't
seem to put out as much heat as usual so maybe it was partially closed and
just shut completely Sat A.M. If it happens again I think I will beat on it
and try to get it to cycle before packing up and heading home.
I asked Dewey if he would be willing to help forum members with Webasto
questions and his response was, sure, just have them call me, I do it all
the time. In addition to knowing Webasto inside and out, Dewey is a
particularly nice guy.
To give you an idea of his experience, they just ordered 50 Webastos for
vehicles up on the slope and he will be installing them. I would bet he
installs and services more Webastos than anyone else in the US (There might
be someone in Canada who does as much). Here is Dewey's number:
Dewey Robinson
907-274-7795
If you lose the number he is in the Anchorage phone book under Robinson,
Duane M on Karluk St. He does a lot of trouble shooting by phone because
they call him from the slope a lot.
I also learned another thing today; Webastos are available either gasoline
or diesel fired. He showed me the one he has on his Expedition which is gas
fired.
Dewey also told me a bit about the Webasto forced air heaters. I am looking
into replacing one (at least) of my propane furnaces with a Webasto. Dewey
says the largest one will run about 20 hours on a gallon of diesel. He uses
one in his cabin so he doesn't have to get up at night to put wood on. Says
it uses about a pint of fuel to heat all night. He says they are extremely
efficient and reliable and the warranty has been increased from one to three
years.
I realize most of the folks on the forum are probably more into air
conditioning than heat (almost every year we will have a day or two when we
use the air conditioner) but if anyone is into winter camping my experiences
might be helpful so please bear with me as I interject a bit of northern air
conditioning into the discussion.
Jim Magowan
90 SP
Anchorage AK
