Hey POGgers,
Thought I would share a service available to us from Power Trac. It is an engine oil analysis that is performed for no charge (kind of). Here is how it works:
First you call 1-800-DDC-0952 and set up an account. I set one up for my generator motor, and the Series 60.
Next you purchase the analysis kit. This is the "kind of" noted above. The kit costs around $13.00 to $14.00 dollars ea. I purchased some in May 2007 at Covington Diesel, Knoxville, TN at $13.28 each. Most Detroit/Allison places should have them. There are no charges for the lab work.
Then you collect a sample of your oil during the next oil change. Fill out the label, pick the lab closest to your whereabouts, and mail it off. Postage runs about $2.50. You will get a detailed analysis sheet in the mail about 10 days later.
On your second and subsequent samples, the analysis sheet shows a graph on things that have changed significantly. I'm not smart enough to know what all of these things are, or how they relate to our oil samples. What interests me is the phrase "no corrective action required" below the analysis recommendations.
The analysis report attached here is a little hard to read. If someone can tell me how to make it bigger, I'll try again.
Ken
