Results 1 to 10 of 26
Thread: H3 Weights
Hybrid View
    rff105 Guest
    Default H3 Weights
    Here are the weights i got today in the H3 full of fuel and water empty sewage holding tanks. Looks like we don't have much room for people, Featherlite pushed this one to the max. What does not make sense to me is the right side weights being so much higher than the left. Our coach has one slide on the left and i would have thought the left side would be heavier. The scale I went to was fairly level but i did only weigh the left rears and right front. I did not weigh every combination. The only item i can think of that is on the right side is the generator and inverters. The interior looks balanced from a weight standpoint to me.
    dalej Guest
    Richard, very good post! I hope that you stimulate more owers to do the same.
    When you know where your at, it makes driving a lot more relaxing doesn't it.
    rff105 Guest
    What tire pressure would you run? 365s front and tag and 315 drive duals
    Prevost plaque says:
    Front 105 psi
    Drive 90 psi
    Tag 80 psi
    Featherlite plaque says:
    Front 105 psi
    Drive 120 psi
    Tag 95 psi
    Minimum by Michelin Specs for weights above:
    Front 110 psi
    Drive 90 psi
    Tag 80 psi
    Apr 2006
    Lake Forest
    2,486
    Personally I would vote for the weights as specified by Michelin. Let's see what others suggest.
    Joe Cannarozzi Guest
    105
    Our bus is considerably lighter than yours 41750 full of fuel and water, loaded with gear.
    As for the drives and tag we run 100lbs. I would not ever run less than 100 in these tires no matter how lite the load. We experience no adverse wear patterns.
    As for your steer. IMO that is an extremely large load to carry up there and 110 seems dead on. 100 is definitely not enough and any more than 110 would create a pressure situation in extreme heat conditions that would put them way too overinflated and hard.
    On a side note we have suspension pressure gauges on trucks, use them like on board scales. The heavier the load the greater the bag pressure. For instance, empty I have 15lbs of air in the trlr bags and loaded (16000 on the axle) there is 60 lbs in them.
    Your R-R bags probably have approximately 5 more LBS than your L-R. I do not think that it is enough of a difference to be a noticeable difference in ride.
    Joe, I'm going to give you something to think about....
    You say initial pressures in excess of 110 PSI will create excessive pressures in hot weather. I'll take the opposite position. You can create a blow out in an underinflated tire in freezing temperatures because of excessive flexing and the resultant heat from that flexing. Conversely, the higher tire pressures will result in less sidewall flex, and less heat generated by a tire.
    When Michelin establishes tire pressures they are reflecting what they have determined is necessary due to the load being carried and they realize that there are going to be high pressures created by the heat of driving or even the heat created by high ambient temperatures or the tire exposed to the sun.
    I would set the tire pressures based on the Michelin charts. FWIW, on our original coach I used 70 PSI for the tag and I got 134,000 on the last set of tires (12.00 tires) and had 3/16 of tread left when they were pulled. No uneven wear.
    As to the air bag inflation pressures this is solely a case of the pressure being dictated solely by the position of the arm on the ride height control valves. The fact that you can read the trailer (and maybe the tractor) air bag pressures tells me a couple of things. With practice you can relate pressure to weight. You could also change the dial on the pressure gauge to pounds of load, and with practice be able to relate that to internal air bag pressure. But in reality it is the position of the control arm on the valves that let air in or out of the system to maintain the ride height. I assume you have left and right hand valves like the coach has. In reality the pressures on one side of the trailer in a steady state turn will increase on the outside of the turn, while the pressures on the inside of the turn will decrease because the valves are merely attempting to maintain a specific height and not pressure.
    Agreed but 105 said that Michelin suggested 110 too. I would have to think that any more would create a noticeable difference in ride quality.
    Agreed too about the air bags. I was trying to relate what on the road knowledge I have on the subject. With greater than 20000 on the drives I would have to guess that pressures there would have to be somewhere north of 75lbs.
    If it were up to me all air ride trlrs. would have a ride height valve for each side as the bus does because of what you describe is happening in a turn, and I can feel that happening behind the wheel. I like to refer to that as-The Bobandweave and when you first go to air-ride it takes a little getting used to.
    I think Mr. K-W does duel ride hieght valves on their 8-bag set-up.
  1. Coach Weights
    By jimshoen in forum MISCELLANEOUS ITEMS
    Last Post: 11-28-2008, 02:02 PM
