Results 1 to 10 of 39
Thread: Tire Replacement
    Default Tire Replacement
    I am in the process of shopping for tires for the back tag and rear duals. I have recieved quotes of approx. $765.00 each for Michelins and about half that for Firestones. Of Coarse , there are several Japanese tires and other American tires I can get quotes on as well.
    Putting aside the Chinese tire discussion, what other than Michelins do other POG members use and why. Is Firestone a reliable tire? Are there others to consider.
    Since mileage is not as much a factor as age, do some tire companies hold up as well as Michelin.
    Gary,
    I think we are all interested in the response to your questions.
    All I can say right now is the Chinese tires still hold air and they are still riding as good as the Michelins based on the unscientific sense I get in my rear end (mine, not the bus's).
    But one or two buses worth of experience is severely lacking in depth of information. The real question should be directed at the charter bus companies in your area, especially the larger ones. They can accumulate data very fast and their concerns while based on tread wear unlike ours based on age will mirror ours with respect to on-road failures, smoothness of ride, ability to stay in balance, etc.
    The biggest bus companies around here are school bus operators and that is not a parallel to our concerns.
    Feel like doing some research in your quest for tires and writing an article?
    Lake Forest, CA
    293
    Default Tires
    GaryD,
    When I purchased my Eagle bus, it had 3 different kinds of tires in 6 different stages of wear. The first thing I did was to buy 8 new Goodyears, I think G357, in 24 1/2". I had them on the bus for over 4 years, Alaska and back, Texas and back, Colorado and back a few times, Branson and back, etc. No complaints at all. Mike "Buster" Simmons had Goodyears on his bus. I am due for new tires this spring, and I am going to give Goodyear a serious look.
    Ken
    Alexandria
    2,161
    Gary,
    The New H3 had Toyo's all around. So far am very pleased and had a recent price quote of $500 per tire plus mounting.
    Mike
    win42 Guest
    Gary: I put Sumitomo tires on my Royale. They were a step up in ride mainly because they replaced tires that were beyond their time. I will look to Goodyear first the next time around, only because they are an American company. I do not think we are buying more with the Michelin name. We only get 60 months use from them. We may find a way to lease them like the major companies do. We keep them for the first two years and let them have them and wear them out. If this arrangement could be structured to save us money in the long run, why not. I'll check with my cousin that drives for Walmart and see how they handle theirs. I guess our weird sizes will blow a hole in this theory.(no pun intended)
    Petervs Guest
    Hi Gary,
    Well, we all get to the tire problem eventually.
    First off, we do not all use the same size tires, so it would be helpful to state what size we are talking about when we post about tires.
    My coach has 315-80R22.5 Michelins now, and I was recently quoted $740 each installed. This is an uncommon size, no place stocks them, and they cost a lot more than the more common 12 R22.5 I got about 3 quotes and they were all very close. I was only asking about Michelins at the time.
    Further research led me to a price of $325 delivered to me but unmounted for Chinese rubber tires in the same size. I would have to pay about $70 each for mounting, balancing, and disposal at some local shop. That makes it 55% of Michelin all done with no shop to complain to if there was a problem. I decided I would rather keep the Michelins on there for 10 years than drive around on Chinese for 5 years each; at essentially the same net cost.
    Then I started searching the net and found there are quite a few exporters who will gladly sell you a container load of tires at lower prices. Turns out 240 tires of my size fills a container . The price each would drop to about $250 plus the mount and balance. But I would have 232 tires left over, perhaps some of my POG buddies would like them? 30 coaches equals a container load. That is not too bad, but the savings are not that incredible either.
    So far I have done nothing, the coach is in the garage for now so there is no urgency yet.
    I also found the California Tow Truck Association has some kind of special deal with Michelin to get tires at quite a savings. They are shipped to a Michelin dealer who installs them for you. Those worked out to about $600 each, but I never got an answer from the CTTA . I was thinking I could easily start a tow operation, right? Then again, maybe POG could get a similar discount deal arranged with Michelin. I have no clue how to set that up though.
    Looking forward to hearing further ideas from you all.
  1. Aux Air Compressor Replacement
    By Johnny in forum MISCELLANEOUS ITEMS
    Last Post: 01-06-2010, 07:09 PM
  2. Replacement Hoses
    Last Post: 01-21-2008, 09:38 PM
  3. ZIP DEE Replacement
    By garyde in forum Prevost Shells and Prevost Car Company
    Last Post: 08-06-2007, 02:20 AM
  4. Tire Pressure Monitoring for $4.99/tire!
    By Ben in forum Engines, transmissions, axles and wheels
    Last Post: 03-27-2007, 09:59 PM
  5. Air Bag Replacement
    Last Post: 02-19-2007, 10:05 AM
