Results 1 to 10 of 19
Thread: Air Belt Tensioners
Threaded View
    Default Air Belt Tensioners
    I have 2 different stlyes on this bus and have no idea if they are both original or not or if this is something other folks are seeing on theirs.
    The A/C one is brass with threaded ends for getting it apart. The ends on the one for the fan are held on with large c-clips and it is not brass.
    Is this normal or has something been changed here? Does anyone else have 2 different belt tension cylinders?
    Found a few issues back there this afternoon. I put a new control valve for the belts above the doors and found that the regulator its hooked to to be making bubbles at the flange. Was able to take a 3/8 I think, and tighten up all the flange bolts on it and it stopped leaking. Nice tip Jeep. Found a rotton air line where the feed line to those cylinders T-s off on the motor too.
    Will tomorrow be the first morning I find it with the suspension still up????
  1. BX 93 Belt for A/C on CC
    Last Post: 04-21-2009, 09:33 PM
  2. Fan Belt Problems
    By JIM KELLER in forum Engines, transmissions, axles and wheels
    Last Post: 10-08-2007, 08:41 PM
  3. Beautiful Fan Belt
    By lewpopp in forum Busted Knuckles and Greasy Jeans
    Last Post: 06-10-2007, 08:17 AM
  4. Fan Belt needed
    By lewpopp in forum WHERE TO FIND STUFF: Links and Resources
    Last Post: 05-08-2007, 11:18 PM
  5. Alt Belt Tension Gauge
    Last Post: 07-11-2006, 10:26 PM
