Results 1 to 10 of 12
Thread: 1997 Marathon/Cruise Air ?
    Mar 2007
    Reno, Nevada
    237
    Default 1997 Marathon/Cruise Air ?
    Hi.
    We are really enjoying the 1997 Marathon XLV that I purchased in February. However, I am having a recurring problem with the Cruise A/C's. Three units on this coach, which is barely adaquate in the southwest. The rear unit regularly shuts down and flashes the "HI PS" code which means too high pressure. I have also had the front unit do the same. I have had it into Desert West Coach twice for them to check it out. They found the freon charge to high the first time and nothing the second time. Still I have the same problem. The filters and coils are all clean and the condensate drain pans are working and clean. Are these units just tempermental and overworked?
    Thanks,
    Jim
    775-843-8656
    dalej Guest
    Jim, these cruisairs are very nice units, they need little maintance. You are having only the problems that the service person fixed or tryed to fix. If he has over filled them then you are suffering the mistake.
    I think at this point, it might be wise to have them vaccumed and refilled to the proper levels. Have them checked for a vaccume hold and then refill.
    We can sit in 100 plus degrees and use only 2 of the three and have them set at 2/3rds of the max. setting.
    Not running down the road though, thats a different story. Have to run the dash air.
    Wilsonville, OR 97070
    852
    Jim
    I came back from Las Vegas at the end of June and fried down their. I also have 3 CruisAir units. I got HI PS reading also and while I was having the unit checked out I was told that the compressor discharge air was too close the intake duct. This cause the unit to get hot and hotter increasing the pressure. So I created a housing to devert the air intake and discharge away from each other. I will not be going back to LV to test it. The other thing to check is if the compressor fan is running if it doesn't the unit gets hot again and you get a HI PS reading and shutdown.
    GregM
    Jim,
    We have discussed this scenario often on this site and the Prevost-Stuff site.
    Your experience should be noted by everybody seeking a coach. Cruise Airs are excellent for providing heat and cooling to a parked coach. They are less ideal as the AC source for a coach that is in motion, and in the case of a 45, three are inadequate when dealing with high temperatures.
    Your condensing units are pulling in cooling air that is extremely hot. The highway or road is absorbing heat from the sun and radiating it back up. You are finding that does not provide sufficient cooling for the condensing unit and your AC shuts down.
    If a coach does not have OTR, it should have roof airs where the air passing over the condensing unit is ambient and is not heated air radiating up from the highway.
    Going further, if the coach is a 40, three typical roof air or Cruise Airs will likely be adequate, but a 45 needs a forth unit or the coach needs to stay out of the hot temperatures.
    Others will disagree, but these coaches all need OTR air to keep us comfortable in all conditions. It is dumb to pay what we do for them, and then find out a guy in a Winnebago is a lot more comfortable than we are.
    3,775
    Jim,
    My 97 Marathon has 3 cruiseairs and they worked great, both sitting still and on the road. Jon has a good point on the number of A/C's, mine was a 40, but a 45 is a lot to cool with only 3. I never experienced any heat related issues with the intake, but was never anywhere exceeding 100 degrees either. If you get them running and solve your head pressure issues, you can adjust the SMX controls to increase the fan speed that may help inside.
    I wish we could get someone from the Cruise Air company along with a roof air manufacturer to weigh in on this issue.
    I had similar issues with Cruise airs as Jim on a 95 degree day between Jamestown NY and Knoxville. The bus system tripped a breaker and would not run so I attempted to run the Cruise Airs. They ended up cycling on the over temp switch in the condensing units and for all practical purposes ceased functioning. Yet when the bus was stopped, and providing shade to the ground beneath it, the Cruise Airs worked perfectly.
    The roof air systems have a reverse problem that has likely been addressed in the engineering of the units. The heat radiating from the roof of the RV when stopped should have the same impact as when Cruise Airs are picking up heated air from the road. They may have a larger condenser coil or the air flow may be better.
    In Tom's case it may be that in his Marathon the air intake and exhaust may be more efficient than on my Liberty. Without expert input we can only speculate.
    Jim, if you are trying to use the units right immediately after pulling into a hot asphalt or cement parking pad, the thing to do is hose down the pad under the bus where your units draw air from underneath. If the parking area is too hot, you will be drawing hot air up into your unit which will give you that high pressure signal.
    Mar 2007
    Reno, Nevada
    237
    Default Thanks for the Leads
    Dale/Gary/Greg/Jon/Tom,
    Thanks for the info.
    I'm picking the bus up in the morning, and will also call Marathon and pick their brains.
    It is likely the charges aren't exactly right.
    However, DWC says you almost need to set them when the outside temp is 110F+ to get them correct for operations in the desert.
    Different line set lengths etc.
    Heading off to Oregon in a week.
    Maybe it will be better going north.
    I've been told that when I get the Hi PS shut down, to turn the unit off wait 10 minutes and start it up again?
    Jim
    dalej Guest
    Forgot to add to keep the interior fans on high as not to freeze up the condenser. Good Luck!
    I had the same issue with my CruiseAirs when I first purchased the bus. Driving back from SLC Utah to Las Vegas in 120 degree heat, and all the CruiseAirs shut down.
    They really do not like running in extreme hot temperature when driving. Once parked, and temps cooled down they were fine.
    I am now able to keep the coach pretty darn cool with the Country Coach air, and only need to add CruiseAir occassionally. IF I did run CruiseAirs during the summer in the desert, I would try cycling them, maybe 30 minutes apiece, keeping one off, two one, letting one cool down?
    ray
  1. Nice 1997 Liberty at Ebay
    By Alek&Lucia in forum Ah, Nice Coach...
    Last Post: 09-24-2008, 06:06 PM
  2. cruise air again
    By gmcbuffalo in forum Ah Houston, I think we have a problem...
    Last Post: 12-25-2007, 06:57 AM
  3. Cruise Air...
    By dalej in forum PARTS AND PIECES FOR SALE OR TRADE
    Last Post: 05-07-2007, 07:31 PM
  4. 1997-2001 Prevost: WTB
    By Jim_Scoggins in forum MISCELLANEOUS ITEMS
    Last Post: 04-28-2007, 02:50 PM
  5. 1997 Marathon - Purchase Jitters
    By truk4u in forum Target Practice
    Last Post: 08-12-2006, 09:47 AM
