Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Generator Malfunction
  1. #11
    Jasper
    3,775
    Mango - You know where they came from, snif, nif, snif....
    Dale - Has to be a cutoff somewhere, a quick call to Marathon should solve your switch location problem.. I may be inside the battery box on the side.
  2. #12
    Mar 2006
    Santa Barbara
    3,177
    Tom, I think your having phantom itch syndrome. You know, like when you loose a foot.
  3. #13
    Nov 2006
    Huntsville
    3,135
    I will give Marathon a call on Monday and see what they say. Surely there is a switch somewhere. I have tried duplicating the problem several times, and it hasn't happened again, so maybe it was just because I had let it set too long without starting it.
    Dale & Paulette
  4. #14
    Jasper
    3,775
    Thanks Gary, I thought something was missing!
  5. #15
    Nichols Hills
    2,465
    Now Gary, the CrakMan is pretty sensitive since he is cruising around in a POS coach and I dont think it is his foot that's missing, so take it easy on him. And we won't mention the Jeep Liberty.........
  6. #16
    Nov 2006
    Menifee California
    994
    Default Jdub
    Hey Jerry, ya reckon GASTRUKSTER's liberty came with a free Rosie O'donnel tee shirt ?
  7. #17
    Nov 2006
    Huntsville
    3,135
    As a followup to the problem I had with my generator, I did the following. I removed the cover from my control box, and noticed that one of the relays was almost out of its socket. I verified that this was the relay that controls my fuel pump and hour meter, inspected it and pushed it firmly in the socket. I assumed that this loose connection could have caused the problem thta I was having.
    Called Marathon a few minutes ago, and the tech said this is the same relay that controls my preheater for the genereator, and that it might be bad. Once I told him it had been out of the socket by almost 1/4', he said this could easily have been the problem. He said the loose relay could have been causing a ground problem. Since I have not been able to duplicate the fault, I assume the problem is solved.
    I did ask the tech if there was a disconnect for the 12V feeding the generator, and he said there was not. If I have the problem again, I will just pull the relay.
    Dale & Paulette
  1. Door Latch Malfunction
    By Jamie Bradford in forum Ah Houston, I think we have a problem...
    Last Post: 11-22-2019, 10:14 PM
  2. Oil for Generator
    Last Post: 07-11-2009, 09:33 PM
  3. Generator - What have I done?
    By aggies09 in forum Ah Houston, I think we have a problem...
    Last Post: 10-28-2008, 11:07 PM
  4. Generator Oil?
    By adamdegraff in forum Busted Knuckles and Greasy Jeans
    Last Post: 09-21-2008, 08:07 AM
  5. New use for bus generator..
    By dalej in forum MISCELLANEOUS ITEMS
    Last Post: 01-02-2007, 10:22 PM
