Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: How often do you grease the chassis?
    dreadnought Guest
    Default How often do you grease the chassis?
    The Prevost owners manual calls for a grease job between oil changes as part of a 6,250 mile service. How many of yall actually do this? other than Jon, of course. I called around to local coach companies trying to find someone to do it and they say they do a complete service at 12 or 15,000 miles and nothing in between other than checking tires, fluids etc.. I don't have the time or the pit to do it myself and the coach operators don't act like they want to fool with a motor home owner, unless they have nothing to do on their own coaches. I even called Prevost and got a round about answer that most owners come in for full service only. We always serviced our over the road trucks at 10,000 miles which of course included a grease job. I know off road and dump trucks are greased weekly. How critical is this grease job every 6,000 miles?
    Joe Cannarozzi Guest
    Twice a year for us, spring and fall.
    Aug 2006
    Houma, LA
    1,783
    Bill,
    I had my coach greased in January 2006 with 42,000 miles on it.
    And I had it greased again last week (May 2007) with 72,000 miles; the mechanic in the truck stop told me that all of the grease zerts were full. It really didn't need a grease job.
    But what the heck, it's only $25.00. I would say it depends on how many miles are put on the chassis/year and what kind of driving conditions you operate the coach in.
    Tuga & Karen Gaidry
    2012 Honda Pilot
    Mar 2006
    Santa Barbara
    3,177
    Once a year, Oil and lube or 10k which ever comes 1st. Its a good idea to have someone check out your under carriage once a year for leaks, loose fittings, bots, etc.
    I don't think it really matters a whole lot what our intervals are because almost none of us will ever put enough miles on the chassis for the failure to lube it to show up as problems.
    I do mine with my 5000 mile oil changes, but each fitting only requires a very slight shot. For me, the critical thing is it gives me an opportunity to do an undercoach inspection. I have found a nail in my tire, broken generator exhaust pipe hangers, slight anti-freeze leaks, loose or missing generator or AC baffle bolts, chafing hoses, etc. So more critical to me is the inspection and repair of the very minor problems that could turn into serious problems that would disrupt a trip. It is my opinion that a Prevost or truck repair facility will do the grease job, but will not take the time to do the inspection, looking for even petty issues that could eventually become bigger problems.
    lewpopp Guest
    Jon, as for the coolant, I was inquiring about it at a Mac truck garage and the guy asked me if I wanted the red or the green. I thought different companies just dyed the coolant what ever way they wanted to.
    Is the color the important thing? I doubt it. What I want is the Aluminum friendly, rught? Should I get the stuff that is already mixed 50/50?
    Confused.
    Lew
    Feb 2006
    Bristol, Tn
    1,647
    I am pretty paranoid, no just fairly consistent with greasing the u joints about every 6000 miles, It just drives better knowing it has greasy joints. I think I use my bus a bit more than the average traveler and may be doing a bit more maintenance than the average bus owner except Jon.
    Roger that!
    2008 Liberty DS XL2
    2023 Denali Ultimate
    My 6th Prevost
    Mar 2006
    Santa Barbara
    3,177
    Smile Coolant
    Quote Originally Posted by lewpopp View Post
    Confused.
    Lew
    Hi Lew,
    Mine is green ,and 50/50 is recommended. Make sure it is Coolant for Deisel Engines as well.
    win42 Guest
    Lew: The guys at Detroit Diesel told me you can use any kind as long as it's green in the 8V92. You need to check the PH level with test strips. Wrong coolant balance can cause the cylinder sleeves to eat out from the coolant side.
    Having water service done by experianced people is important.
    Lew,
    There is a Detroit Diesel spec that coolant must meet. You cannot go to the local Auto Zone and pick up twelve gallons of Prestone and be good to go.
    The coolant container will list the various specs it meets and I have never found any automotive anti-freeze that spells it out. I have been able to get the proper coolant however at truck stops or at Detroit dealers.
    Whether it is pre-mixed or needs to be mixed is a personal choice. It is my understanding the green is not compatible with the red so if you have green stick with it. The DD dealer I get mine from recommends the undiluted because of the cost.
    As a general comment the use of the wrong coolant or one that does not test properly could result in severe damage to the cylinder liners, and the few bucks extra that are spent using the right coolant and maintaining the chemistry will be cheap insurance. Further, if the wrong coolant is used there is a possibility the radiator could become blocked due to "silicone drop out" (I hope I spelled that right) and could require premature radiator recoring.
  1. 2008 Prevost chassis vs 2009 chassis
    By utahcamera in forum Ah, Nice Coach...
    Last Post: 04-30-2009, 06:00 PM
  2. Grease Fittings
    Last Post: 04-11-2009, 10:37 AM
  3. Groeneveld CPL Systems Auto Grease System
    By Gary & Peggy Stevens in forum Engines, transmissions, axles and wheels
    Last Post: 04-04-2008, 07:41 AM
  4. Tag axle grease fitting
    By Jim_Scoggins in forum Busted Knuckles and Greasy Jeans
    Last Post: 04-14-2007, 12:09 PM
  5. Chassis grounding
    By ken&ellen in forum The Converters of Prevost Shells
    Last Post: 06-22-2006, 04:07 PM
