Page 5 of 5 FirstFirst ... 345
Results 41 to 49 of 49
Thread: paint?
  1. #41
    595
    Looks great Mike
    Need some paint work on the front of my coach, what’s your hourly rate LOL
    Chuck & Katrina
    2000 Featherlite
    H3-45 Double slide
  2. #42
    965
    What is everyone doing to their busses this week? I am working on my Exterior paint.
    Mike Giboney
    1992 Prevost Country Coach
    #60187
  3. #43
    952
    We will see what if anything I get to this week ... but this is my current should do list ... not the full list of course!!
    Finish setting up the new Bluefire monitor so I can watch the transmission temp. This summer, we had several high sump temperature codes. Three different shops reviewed and found nothing. The analog temperature gauge in the dash reads normally. However the sender is in the retarder circuit and is not driven from the wiring harness mounted thermister that sends the error codes. I have confirmed that the bluefire will read this sensor and will hopefully give me more information. BTW, my scangauge D will not read the trans temp even after working with the scangauge tech department.
    Check Parliament OTR condenser fans to see if both are running
    Re-glue the electronics cabinet latch
    Replace the Aquahot webasto controller and see if it cures the shut down issue.
    Trouble shoot the Aquahot bedroom water pump and backflow preventer. I am not getting water to the coil.
    Figure out why the passenger wiper arm lock nut is loose
    Re-rivet the small front awning mounting plate. No clue how this broke loose
    Re-charge the Spot Free rinse repair
    Re-charge the water softener
    Add air to the tires now that it is cold
    Polish drivers side wheels
  4. #44
    952
    oh, and I ordered a throttle position sensor because that threw a code once on the way to Michigan ... better safe than sorry ..
  5. #45
    965
    Prepping my front cap for paint, i had to remove these 2 buggers. they are the Windshield washer fluid 90 degree fittings
    Mike Giboney
    #60187
  6. #46
    965
    Paint and body work is complete. Just in time for Quartzsite.
    Mike Giboney
    #60187
  7. #47
    952
    Wow, nicely done! That looks great.
  8. #48
    965
    Thanks, did you notice what i did with the Prevost Badge? That is not original.
    Mike Giboney
    #60187
  9. #49
    1,154
    Nice, green prevost lettering. Nice custom touch
  1. Paint codes??
    By sawdust_128 in forum MISCELLANEOUS ITEMS
    Last Post: 07-20-2008, 09:21 PM
  2. Touch Up Paint
    By tdelorme in forum PARTS AND PIECES FOR SALE OR TRADE
    Last Post: 04-18-2008, 08:50 PM
  3. Touch Up Paint
    By tdelorme in forum WHERE TO FIND STUFF: Links and Resources
    Last Post: 03-30-2008, 03:05 PM
  4. New Paint Job
    By JamesJ in forum Ah, Nice Coach...
    Last Post: 01-08-2007, 02:26 PM
