Results 1 to 10 of 13
Thread: F150 front tires wearing Excessively on outside edges
    Dec 2020
    Goldsboro
    174
    Default F150 front tires wearing Excessively on outside edges
    Alignment shop set toe out to try and reduce wear on outside. Still progressing so they have set camber to inside to try and make tire run on the inside edge.
    Anyone have this issue?
    George and Joan
    2006 Royale March 2024
    Goldsboro NC
    2022 Ford King Ranch
    Dec 2024
    Inverness
    26
    The only time I have experienced aggressive outside wear on the toad tires is when I forgot to unlock the steering.
    Something you may look at is the side to side play in your tow bar/hitch setup. I have seen a couple of F150s that were actually slamming side to side while being towed. I stopped one of the drivers. He said he never felt it. There was a lot of play between the tow bar and the hitch receiver. Have someone follow you while you are towing to see if anything unusual is happening both on the straights
    Can you post a pic of the tires?
    Richard Entrekin
    Newell 512, EX
    2007 Marathon 1025, XL II
    Here to learn
    Dec 2020
    Goldsboro
    174
    forgot how to get photos in post
    George and Joan
    Goldsboro NC
    Dec 2020
    Goldsboro
    174
    Default pictures
    here are pictures of tires
    George and Joan
    Goldsboro NC
    949
    Wow, that is crazy! I would not deviate from the factory specs for the alignment. If the toe and camber were properly adjusted in the beginning, I would not have changed them. Something else is wrong. Either you have significantly worn / faulty front end parts or as Richard suggested something is off while towing. I like his idea of someone following you and observing the truck while being towed.
    I assume that the truck drives fine? No pulling or anything?
    949
    As Richard said, are you sure that you have your steering unlocked? Do you test this and watch for the wheels to turn out of the wheel well in a tight corner?
    Dec 2020
    Goldsboro
    174
    The truck does not have locking seering, push button start.
    I can see the wheels turning in the mirror when I turn.
    The truck only has 32K miles and has been aligned every 5 K miles by the same shop
    I watch the truck on the rear view camera when traveling and don't see any odd actions. Still looking for a solution.
    George and Joan
    Goldsboro NC
    949
    I guess I would get a second opinion on the front end integrity and alignment then. That kind of wear only on the outside edge of both tires is definitely peculiar.
    961
    That wear is real bad. I have traveled over 100K miles towing 4 or 5 different vehicles since 2007 and I have never seen anything like that.
    Mike Giboney
    1992 Prevost Country Coach
    #60187
    Dec 2020
    Goldsboro
    174
    Had front checked by another shop and nothing was found. They said everything was extremely tight and no play in anything.
    George and Joan
    Goldsboro NC
