Results 1 to 10 of 13
Thread: House Battery's Charged But won't run inside of coach
    Sep 2020
    GARLAND
    93
    Default House Battery's Charged But won't run inside of coach
    I disconnected the battery cables and tested the house batteries and they are fully charged. They were new 2 years ago. If I am not plugged in or running the generator I don't have power inside the coach. Does anyone have an idea where to look for problem?
    Thanks,
    Norman Martin
    2000 XL Country Coach
    60408
    990
    12 volt power, 110 Volt Power, 240 volt power, Which power are you talking about?
    Mike Giboney
    1992 Prevost Country Coach
    #60187
    Dec 2021
    Hillside
    124
    Norman,
    Piggy-backing off Mike the question is which power....if the batteries are good you should have the 12v power at a minimum but for the 110+ power that would come via the inverters. So if you don't have 110+ you have an inverter issue and in turn if you have neither 12v or 110+ then you probably have an equalizer/converter issue also with the vdc conversion to the 12v side of the house batteries.
    Jerry & Pam
    1993 Marathon XL40
    2021 Jeep Wrangler
    Sep 2020
    GARLAND
    93
    Thanks Mike and Jerry for the response. I'll get with the Magnum tech people and see if they can help me.
    Norman Martin
    60408
    1,044
    Keep us posted and let us know what they say.
    Sep 2020
    GARLAND
    93
    I will call them today, will post results.
    Norman Martin
    60408
