Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Generator/Webasto Exhaust Wrap
Hybrid View
    May 2006
    Diamondhead
    447
    Default Generator/Webasto Exhaust Wrap
    I believe both of these exhaust pipes are wrapped in Abestos cloth which is coming unwrapped. Is there some type of glue or fasterner material to secure these? Is this cloth wrap still available to buy? Thanks for any info! Dan
    Orren Zook Guest
    Quote Originally Posted by DANSS View Post
    Summit Racing, Jeg's and/or probably your local speed shop has an exhaust header wrap that will do what you want. This product is made by Moroso, DEI and a couple of others and usually sells for $10 to $15 a roll
    Danss,
    The Prevost exhaust wrap is usually a sewn material that has hooks upon which you lace stainless steel wire, such as aircraft safety wire. If you are having a problem it might be the wire lacing has come loose.
    lewpopp Guest
    I posted this before and received no answer or I missed it.
    I want to replace the insulation that has deteriorated in my generator compartment. Yes, the stuff that Zimmerman pointed out.m Where can I get the material and what is it. Thanks
    Lew
    Joe Cannarozzi Guest
    How about trying Zimmerman Coach
    Apr 2006
    Lake Forest
    2,486
    Lew, when I made a trip up to Oregon to look at some coaches, they had all been done with a new metalic-like material that was in the generator compartment.
    I asked the salesman about this stuff. It comes from a company up in the Oregon area.
    Here's what info I received:
    You can purchase the material you need from my freind Dick Wright. Phone: 541-744-4333. I didn't see the insulation on his web site: http://www.wricointernational.com/ however you can phone him to order.
    Nice looking stuff, much better hopefully than that foam-like stuff used in original.
    Nov 2006
    178
    Dan,
    We use the wrap on the race car headers and exhaust, especially the pipe that comes thru the driveshaft tunnel opposite the accelerator pedal. When you call Jegs, etc. ask them for safety wire and the tool used to install it after you put the wrap on and you'll be good to go. The wrap won't come off unless you drag the exhaust over a curb or some such.
    Richard Beecher
    96 Vogue XL 40 Beechbus
    07 Suburban
    Stelan73 Guest
    Default Generator Radiator Overflow
    Today after running the generator in low 80 degree temps I put the bus back in the barn and noticed about a pint of antifreeze on the floor from the generator overflow hose. When I checked the generator last week the overflow tank was normal. Any ideas on cause and recommended next steps in problem solving? Thanks.
    Steve
    Steve,
    Had it been serviced and perhaps overfilled?
    Stelan73 Guest
    Default Generator
    We really hadn't run the generator a lot until recently and I "assume" it was serviced when we bought the bus. I'll give it a good running later this week and see if it repeats the burps.
  1. Oval Exhaust Tips for Gen. & Webasto
    By LarryB in forum Engines, transmissions, axles and wheels
    Last Post: 05-31-2010, 06:33 PM
  2. Road Wrap for the bus & toad
    By James in forum MISCELLANEOUS ITEMS
    Last Post: 12-22-2009, 07:48 PM
  3. Exhaust tip
    By phorner in forum PARTS AND PIECES FOR SALE OR TRADE
    Last Post: 11-30-2008, 09:35 PM
  4. Exhaust Leak
    By bluevost in forum Ah Houston, I think we have a problem...
    Last Post: 11-27-2008, 01:58 PM
  5. Webasto/Generator Repairs @ Marathon
    By ajhaig in forum Busted Knuckles and Greasy Jeans
    Last Post: 10-10-2007, 12:41 AM
